Date/Time: Mon, 29 Apr 2024 06:17:07 +0000
Volume Profile - Fill Color
View Count: 1009
[2014-11-11 11:01:46] |
User78442 - Posts: 260 |
This 5 Day profile has considerable volume data that is colored blue (not discernible bid or ask) - Any reasons for this?
NSEA-MZ4 60 Min #5 2014-11-11 10_59_58.591.png / V - Attached On 2014-11-11 11:00:22 UTC - Size: 54.78 KB - 345 views |
[2014-11-11 19:05:43] |
This has to do with the historical data from OEC. It does not have bid volume or ask volume. We started to maintain historical data for this market which will have bid volume and ask volume. This will be as of today. You will need to restart Sierra Chart to access this data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 06:36:03] |
Does this mean that SC only have historic data (inc. volume segmented Bid/Ask) from 11/11/14? Would this situation with OEC be improved if I enabled SC's Realtime Exchange feed to supplement the OEC data? |
[2014-11-12 07:03:00] |
Does this mean that SC only have historic data (inc. volume segmented Bid/Ask) from 11/11/14? Yes.Would this situation with OEC be improved if I enabled SC's Realtime Exchange feed to supplement the OEC data? Yes, but this is an ICE product which has a very high exchange fee of 94.50 USD a month.And being the issue is just with historical data, we could simply load in more historical data. We will look into that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-11-12 08:03:13] |
More historical data has been loaded for the contract. Go to the chart and select Edit >>Delete All Data and Download.
[2014-11-12 08:30:44] |
Thanks - Question; If I designate a chart to be intraday, say a 240m or 1440(1day) is the data ONLY provided by the Trading Platform Data (in this case OEC)? Is SC Historic data only daily data - Do you provide 'historic' minute/tick back-fill for intraday-designated charts?
[2014-11-12 08:51:38] |
The historical Intraday data is provided by a system maintained by Sierra Chart for OEC. The data on that system originates from OEC.
