Date/Time: Tue, 17 Nov 2026 18:28:42 +0000
No NYMEX / COMEX data with Rithmic Direct - DTC [trading], but works with Teton
View Count: 18
| [2026-11-17 17:15:02] |
| User963978 - Posts: 1 |
Hello, I use Rithmic Direct - DTC [trading] (Apex account) only for order routing, and the Denali Exchange Data Feed for market data. My account has the CME / CBOT / NYMEX / COMEX exchange active on Denali. Sierra Chart version 2945. Problem: With Rithmic Direct - DTC [trading] selected, CME and CBOT symbols receive real-time data normally (ESZ6.CME, NQZ6.CME, RTYZ6.CME, ZNZ6.CBOT, 6EZ6.CME). But the NYMEX and COMEX symbols GCZ6.COMEX and CLZ6.NYMEX receive no data. They stopped updating on 2026-11-13 around 13:11 CT. I selected the symbols directly from the Find Symbol list (Futures - NYMEX: CLZ6.NYMEX, CLF7.NYMEX), so the symbol names are correct. When I open CLF7.NYMEX, the Message Log shows: - "Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: CLF7.NYMEX" - "Historical data file for CLF7.NYMEX not available." Test: On 2026-11-17 I switched to Teton CME Routing [trading], and GCZ26_FUT_CME and CLZ26_FUT_CME received data normally right away. When I switched back to Rithmic Direct - DTC [trading], gold and crude stopped receiving data again, while CME and CBOT symbols kept working. So my Denali NYMEX/COMEX subscription works. The problem only happens with Rithmic Direct - DTC [trading] on NYMEX and COMEX symbols. Question: How can I receive Denali market data for NYMEX and COMEX symbols while using Rithmic Direct - DTC [trading] for order routing only? I need Rithmic to trade my Apex accounts. Thank you. |
| [2026-11-17 18:25:36] |
| John - SC Support - Posts: 48559 |
You are only setup for real-time data for the CME Group from our Denali Exchange Data feed for the CME and CBOT exchanges. And you must not be setup to get any data from Rithmic, which is why you get that error from Rithmic. When you are connected to one of the Sierra Chart services (including Teton) you would be getting the delayed streaming data for COMEX and NYMEX. Refer to the following regarding changing your exchange selections: Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
