Date/Time: Thu, 12 Nov 2026 01:01:04 +0000
Indicator Value Label not legible
View Count: 55
| [2026-11-11 21:58:37] |
| Trader8080 - Posts: 3 |
High/Low for Time Period – Extended, Draw Style Transparent Fill Top/Bottom: the value labels on the price scale are drawn faint/transparent on a dark chart background. How can I make the labels opaque and readable while keeping the transparent fill?
| [2026-11-11 22:18:29] |
| John - SC Support - Posts: 48504 |
Please get us an image of what you are seeing. The labels do not follow the transparency setting for the fill styles, so we are not understanding what you are seeing.
| [2026-11-11 22:26:39] |
I am tying to post and image - first time user - struggling....
| [2026-11-11 22:28:39] |
Here are the instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) The simplified version is the following: - Select "Edit >> Screen Images >> Upload Main Window Image" - The Message Log will open with information on the URL for the image and telling you that the URL has been copied to your clipboard. - Come to this thread and paste the URL and then save the post. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-11-11 22:31:28
| [2026-11-11 22:36:55] |
https://www.sierrachart.com/image.php?Image=1794436570410.png see the labels on the right axis in the largest chart Date Time Of Last Edit: 2026-11-11 22:37:46
| [2026-11-11 22:42:53] |
It looks like you enabled the option for "Label" and set the color to "black". Refer to the following: Chart Studies: Subgraphs Tab >> Label For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
