Date/Time: Fri, 03 May 2024 08:22:39 +0000
Date based rollover rule not defined for symbol (BZ)
View Count: 1096
[2014-11-11 02:05:05] |
rhovega - Posts: 279 |
Hi SC, Have a problem with BZ-201412. I have BZ-201412 set up for Continuous Futures Contract - Volume Based Rollover. I'm getting the following error message: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart Using your data feed. Can you please help? Exact error message is as follows: BZ-201412-NYMEX [CV] [M] Daily #12: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-11-10 21:01:08 BZ-201412-NYMEX [CV] [M] Daily #12: There are no continuous futures contract symbols. Loading data normally. | 2014-11-10 21:01:08 Thank you. |
[2014-11-12 05:12:36] |
The rollover symbol settings have been set up for this symbol. Restart Sierra Chart to get them.
