Date/Time: Mon, 09 Nov 2026 22:27:29 +0000
Connecting Prop account
View Count: 27
[2026-11-09 17:58:28]
User563703 - Posts: 16
Is there a way in which I can connect my Top Step Prop account to my Sierra Chart, so that when I execute a trade on my SC screen the trade is simultaneously activated on my Top Step. The videos I have watched say that you have to use Rythmic data but I know that SC frowns upon that. So, what is the correct way, thank you JWD.
[2026-11-09 22:01:10]
John - SC Support - Posts: 48479
You can use Sierra Chart with Top Step and send trades from Sierra Chart to Top Step. To connect to a Rithmic account, follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
If you are asking if you can trade your live account with copies to Top Step, then this is not available with the built-in tools in Sierra Chart. There are third party tools that do this, so you would have to see if there is one that will do what you are wanting.
Whether you use the data from Rithmic with Top Step, or you use our data is up to you. We definitely do not think much of the Rithmic data, but it is supported. The main thing to keep in mind is that the Rithmic data has a lack of historical data. Refer to the information at the following link for our thoughts on the Rithmic data:
Rithmic Trading Platform Service: Rithmic Support Policy
But we see that you are already setup to get data from our Denali Exchange Data Feed. So there is nothing you would need to do in order to get our Denali data with the Rithmic connection. This would occur automatically. Refer to the following:
Denali Exchange Data Feed: Integration with Trading Services
If you are going to be trading separate accounts (your personal account and a Top Step account) then we recommend having a second installation of Sierra Chart to separate these connections. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
