Date/Time: Thu, 29 Oct 2026 06:15:06 +0000
[User Discussion] - Day Light Saving Schedule Outside USA
View Count: 27
[2026-10-29 05:07:38]
Tony - Posts: 730
When set a Time Zone outside USA, it could get confused, either the Day Light Saving schedule is different, or your place permanently stays (or doesn't observe) Day Light Saving, I find a way to display the cash session on the screen (New York Time 9:30 to 16:00), and automatically set the correct Session Start/End Time in Chart Settings every time when Day Light Saving schedule changes (either at your place or in USA), I thought it would be handy, but the study has its limitations, I will explain, please make sure it matches your need before install:
I assume you trade US Futures, and 'Use Evening Session' is set to 'No', Session starts at New Your Time 18:00 previous day to 17:00, and you set the Time Zone as the place you live, and trade Cash Session only.
The screenshots are examples when the Time Zone is set to New Delhi and London.
Here you can download the study, and instructions how to compile it
Study for Holiday Reminder
It also has the features of Holiday and Events Reminder, if you don't like event reminder, just set "Number of Event Times to Display" to zero.
Please be aware that since times saved in TAL are UTC, so, every time you change the time zone, the times in TAL will also change accordingly, it has nothing to do with this study.
Date Time Of Last Edit: 2026-10-29 05:23:36
imageLondon.png / V - Attached On 2026-10-29 05:15:29 UTC - Size: 58.46 KB - 10 views
imageNewDehli.png / V - Attached On 2026-10-29 05:16:39 UTC - Size: 56.53 KB - 8 views
