Date/Time: Mon, 23 Nov 2026 15:07:08 +0000
[User Discussion] - Study for Holiday Reminder
View Count: 1363
[2026-04-03 18:16:34]
Tony - Posts: 736
I wrote a study for holiday reminder, so you will never have to worry that you would forget a holiday when market is closed (or close early), it reminds you on the holiday and one day ahead.
In case you need instructions on how to build custom studies from source code, here is the link: How to Build an Advanced Custom Study from Source Code or follow this "Cheat Sheet":
step 1: Download the attached .cpp file and save it in "C:\SierraChart\ACS_Source\"
step 2: Analysis -> Build Custom Studies DLL
step 3: in "Build Advanced Custom Studies" window, go:
File -> Select Files (choose HolidayCheck.cpp)
step 4: Build -> Remote Build - Standard (close window when done)
step 5: Anaysis -> Studies
step 6: click "Add Custom Study" button around bottom left
If I found any problems / issues after it had been added to "User Contributed Studies" on June 27, 2026, I will fix and update the .cpp file attached to this post.
July 04, 2026 updates:
- "Flash Message" didn't work, fixed;
- added "Test Message", set yes to adjust input values, when there is no holiday message to display
July 06, 2026 updates:
- added simplified events reminder for US market, High and Medium impacts only.
- Note: I'm not capable to get "actual numbers", and it will never happen, sorry.
- changed the study name to "Events and Holidays Reminder (Simplified)"
September 03, 2026 updates:
- added "Use Keyboard to Relocate Message
- when "Yes", the message will follow cursor when ctrl-alt-shift pressed at the same time
- you can relocate the message on the screen easily without going to Study Settings.
October 28, 2026 updates:
- added "Show Cash Session Hours
- when "Yes", the study will show CME cash session as your local time
- and automatically adjusted according to your Day Light Saving schedule
Date Time Of Last Edit: 2026-11-01 22:22:09
imageScreenshot.png / V - Attached On 2026-07-14 04:02:08 UTC - Size: 169.25 KB - 129 views
attachmentHolidayCheck.cpp - Attached On 2026-11-01 22:22:06 UTC - Size: 13.66 KB - 25 views
[2026-04-03 18:23:17]
AlgoAlpha_1 - Posts: 10
Nice!
[2026-05-24 16:51:14]
Tony - Posts: 736
Market will be closed 12:00 pm CDT on May 25, Monday
[2026-06-25 07:15:32]
Sierra_Chart Engineering - Posts: 25463
Would you like us to add this to User Contributed Studies?
[2026-06-25 13:17:36]
Tony - Posts: 736
Hi Engineering Team, that would be great, thanks!
just curious, wonder why the User contributed Studies shows v2551?
I am currently use SC 2920. (attached a screenshot)
Date Time Of Last Edit: 2026-07-06 06:16:16
[2026-06-25 22:05:21]
User contributed studies will be rebuilt in the next version and be up-to-date.
Date Time Of Last Edit: 2026-06-25 22:05:34
[2026-06-28 01:50:11]
Tony - Posts: 736
I saw the new "User Contribute Studies" that includes this study, that is quite a compliment to an amateur coding hobbyist, thanks.
I just noticed that I didn't add description, my bad, didn't realize that, I fixed it and tested. (attached .cpp in post #1)
Not sure if it is possible to update in future version, if it would be too much work for you guys, please leave it as is, either way is perfect.
Thanks again!
Date Time Of Last Edit: 2026-07-06 06:16:32
[2026-06-29 14:13:17]
We will update the study now in User Contributed Studies.
