Date/Time: Mon, 26 Oct 2026 20:43:45 +0000
Multiple accounts
View Count: 16
[2026-10-26 19:08:49]
User572037 - Posts: 40
Is there a way to save the settings so 'Enable order allocation to trade accounts' stays selected?
Seems I have to select it every session & when I forget it leads to uneven accounts.
Thanks.
[2026-10-26 19:41:00]
John - SC Support - Posts: 48333
First, refer to the following setting and make sure it is set the way you want it:
Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General)
Second, the specific setup information for the Order Allocation to Trade Accounts should not change unless something specifically changed it. Keep in mind that you can setup the Order Allocations to be part of the "Trade Configurations" and/or shared through linking with other Trade Windows. Refer to the following and the item below it:
Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Linking
