Date/Time: Mon, 30 Nov 2026 02:13:40 +0000
[Locked] - Backfill request 18M in 45 min
View Count: 338
| [2026-10-12 14:52:07] |
| MarcOh - Posts: 178 |
That's definitely not normal—18 million records (ticks/records) in under 45 minutes suggest that Sierra Chart is either reloading historical ticks in an infinite loop or buffering a massive amount of redundant data. Is anyone else having the same problems? Does anyone have any advice? Other than telling me to buy CME data to get around whatever the issue is. Thank you |
| [2026-10-12 15:14:06] |
| Sierra_Chart Engineering - Posts: 25523 |
We see you are using Rithmic data. So we cannot help with this. Use the Denali Exchange Data Feed: Denali Exchange Data Feed No this could not be true: Sierra Chart is either reloading historical ticks in an infinite loop or buffering a massive amount of redundant data.
| [2026-10-13 06:20:50] |
GM once in a while this topic comes up and- since 2019- its exhausting to be honest. Im keeping a very close key on the data flow and the delays. Never mind. If you didnt have the best TPO profile chart Id have left ages ago. I thnk you. |
| [2026-10-28 19:44:17] |
This post, is an overwhelming and superb example, of why we provide our own data feeds. It would be extremely stupid for us to be supporting external data feeds. This is why we do not support CQG Data Feed for CME and EUREX. The only reason we support Rithmic, is because of CME market data policies. But when you have problems, as we have warned repetitively you will, you need to use the Denali Exchange Data Feed. There is no validity whatsoever to your complaint. It is simply that you are ignoring a proper solution that we have available to you. This post only convinces us, that we probably should terminate support for the Rithmic Data Feed. What is the purpose for us to be supporting other data feeds that do not work properly, when customers are only going to post garbage problems about them here and blame us for them! There is no reason for this and we would be exceptionally hyper stupid to allow this this situation to continue. This thread is now locked! You are posting false information. You have been warned about the problems with Rithmic data ahead of time. You are only wasting our time here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-29 12:49:25
