Date/Time: Sun, 29 Nov 2026 14:31:53 +0000
Global Profit Loss Management Account Assignment
View Count: 242
| [2026-10-12 05:25:26] |
| John M - Posts: 189 |
Setting up the GPLM window for an active account presents the following issue: Open the window and the Account defaults to acct Fxxxxxx I change it to acct Uxxxxxx, out of a selection of several different available accounts (Uxxxxxx, Uyyyyyyy, Uzzzzzz and Fxxxxx) it shows Uxxxxx in the appropriate slots for profit and loss setting and then hit OK and close the window. If I open the GPLM window again, it displays acct Fxxxxx again and not Uxxxxxx. (!?!) ->How do I know it actually assigned and is staying on the desired account of Uxxxxxx ? <- It's a bit concerning if I can trust this thing or not for account assignment and I don't want to test it live and have it make a mistake. Everything else is working fine in Simulation. thank you |
| [2026-10-12 15:48:15] |
The Global Profit/Loss Management applies to all Trading Accounts that are listed in the window. There is no ability to set different controls for different accounts. When you make a change for one account, it applies to all the listed accounts. You can try this out in Simulation Mode by having multiple accounts. Refer to the following: Global Trade Settings Windows: Number of Simulation Accounts (Global Settings >> General Trade Settings >> General) You can also test this with the "Simulated Futures Trading Service", as this also allows you to have multiple accounts. Refer to the following: Simulated Futures Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-12 16:03:34] |
And this applies to non-Sim accounts also? It covers all listed real accounts? Just double checking to make sure I understand you correctly. thank you |
| [2026-10-12 16:32:47] |
What we stated about how the Global Profit/Loss works is true for non-Sim accounts as well as Simulated accounts. The simulation state does not matter. Any changes to the Global Profit/Loss Management apply to all accounts that are part of that connection (all accounts listed in the "Status Trade Account" at the top of the window).
