Date/Time: Sun, 29 Nov 2026 14:31:47 +0000
No data feed
View Count: 370
| [2026-10-11 17:50:22] |
| User564204 - Posts: 5 |
I use TETON CME order routing and AMP as my clearing firm, but since 29 September I don't receive data feed anymore. Could you please help me with the setting. Thanks, Ursulavita
| [2026-10-11 20:15:52] |
| Sierra_Chart Engineering - Posts: 25523 |
Yes we can help. Everything looks fine on your account to receive real-time CME and EUREX data. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-12 06:39:03] |
Thank you for your kind reply. Here is the copy of my log related to the problem of receiving data feed on DAX 2026-10-12 02:31:16.995 | Software version: 2888 64-bit 2026-10-12 02:31:16.995 | Primary Thread ID: 21644 2026-10-12 02:31:16.995 | Usage end date: 2026-11-11 2026-10-12 02:31:16.995 | Enabled for: Advanced Features 2. 2026-10-12 02:31:16.995 | Enabled for: Sierra Chart Historical Data Service. 2026-10-12 02:31:16.995 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-10-12 02:31:16.995 | Enabled for: Delayed Denali Exchange Data Feed. 2026-10-12 02:31:16.995 | Enabled for exchange2: CME 2026-10-12 02:31:16.995 | Enabled for exchange2: EUREX EOBI 2026-10-12 02:31:16.995 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-10-12 02:31:16.995 | Current selected Data/Trading service: Teton CME Routing 2026-10-12 02:31:16.995 | Custom symbol settings values: enabled 2026-10-12 02:31:16.995 | Chart Update Interval: 400 2026-10-12 02:31:16.995 | Intraday Data Storage Time Unit: 0 2026-10-12 02:31:16.995 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-10-12 02:31:16.995 | 2026-10-12 06:31:16 Local computer time in UTC 2026-10-12 02:31:16.995 | 2026-10-12 02:31:16 Local computer time in SC Time Zone 2026-10-12 02:31:16.995 | 2026-10-11 16:41:26 Server time in UTC 2026-10-12 02:31:16.995 | Local computer UTC time and Server UTC time difference: 9 seconds. 2026-10-12 02:31:16.995 | Notice: Your computer's clock is off by 9 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2026-10-12 02:31:16.995 | Program path: C:\SierraChart\ 2026-10-12 02:31:16.995 | Data Files path: C:\SierraChart\Data\ 2026-10-12 02:31:16.995 | OS Version Number: 10.0 2026-10-12 02:31:16.995 | Locale Setting: C 2026-10-12 02:31:16.995 | Crash reporter started: true 2026-10-12 02:31:16.995 | 2026-10-12 02:32:51.724 | FDAX1226.EUREX [CBV] Daily #5 | Reloading chart. 2026-10-12 02:32:51.724 | FDAX1226.EUREX [CBV] Daily #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.724 | FDAX1226.EUREX [CBV] Daily #5 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.732 | FDAX1226.EUREX #18 | Reloading chart. 2026-10-12 02:32:51.865 | FDAX1226.EUREX [CBV] 1 Day #11 | Reloading chart. 2026-10-12 02:32:51.865 | FDAX1226.EUREX [CBV] 1 Day #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.865 | FDAX1226.EUREX [CBV] 1 Day #11 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.896 | FDAX1226.EUREX [CBV] 540000 Volume #13 | Reloading chart. 2026-10-12 02:32:51.896 | FDAX1226.EUREX [CBV] 540000 Volume #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.896 | FDAX1226.EUREX [CBV] 540000 Volume #13 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.926 | FDAX1226.EUREX [CBV] 1500 Volume #21 | Reloading chart. 2026-10-12 02:32:51.926 | FDAX1226.EUREX [CBV] 1500 Volume #21 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.926 | FDAX1226.EUREX [CBV] 1500 Volume #21 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.944 | FDAX1226.EUREX [CBV] #7 | Reloading chart. 2026-10-12 02:32:51.944 | FDAX1226.EUREX [CBV] #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.944 | FDAX1226.EUREX [CBV] #7 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.958 | FDAX1226.EUREX [CBV] #8 | Reloading chart. 2026-10-12 02:32:51.958 | FDAX1226.EUREX [CBV] #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.958 | FDAX1226.EUREX [CBV] #8 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.971 | FDAX1226.EUREX [CBV] #14 | Reloading chart. 2026-10-12 02:32:51.971 | FDAX1226.EUREX [CBV] #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:51.971 | FDAX1226.EUREX [CBV] #14 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:51.996 | ESM26_FUT_CME #9 | Reloading chart. 2026-10-12 02:32:52.137 | FDAX1226.EUREX [CBV] #3 | Reloading chart. 2026-10-12 02:32:52.137 | FDAX1226.EUREX [CBV] #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.137 | FDAX1226.EUREX [CBV] #3 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.148 | FDAX1226.EUREX [CBV] #19 | Reloading chart. 2026-10-12 02:32:52.148 | FDAX1226.EUREX [CBV] #19 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.148 | FDAX1226.EUREX [CBV] #19 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.161 | ESM24_FUT_CME [CBV] 10 Sec #22 | Reloading chart. 2026-10-12 02:32:52.161 | Added historical Intraday data request for ESM24_FUT_CME to the queue. 2026-10-12 02:32:52.161 | Intraday data recording state for symbol ESM24_FUT_CME is set to download 'Pending'. 2026-10-12 02:32:52.161 | Triggering next historical data download in queue. 2026-10-12 02:32:52.164 | ESM24_FUT_CME [CBV] 10 Sec #22 | Performing continuous chart historical Daily data download for symbol ESM24_FUT_CME starting at last date in file. 2026-10-12 02:32:52.164 | Added historical Daily data request for ESM24_FUT_CME to the queue. 2026-10-12 02:32:52.164 | Triggering next historical data download in queue. 2026-10-12 02:32:52.177 | ESM24_FUT_CME [CBV] 10 Sec #22 | Waiting for historical downloads to complete with the IDs: 99, 100, 2026-10-12 02:32:52.209 | FDAX1226.EUREX [CBV] #17 | Reloading chart. 2026-10-12 02:32:52.209 | FDAX1226.EUREX [CBV] #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.209 | FDAX1226.EUREX [CBV] #17 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.238 | FDAX1226.EUREX [CBV] 5000 Volume #27 | Reloading chart. 2026-10-12 02:32:52.238 | FDAX1226.EUREX [CBV] 5000 Volume #27 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.238 | FDAX1226.EUREX [CBV] 5000 Volume #27 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.259 | FDAX1226.EUREX [CBV] #23 | Reloading chart. 2026-10-12 02:32:52.259 | FDAX1226.EUREX [CBV] #23 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.259 | FDAX1226.EUREX [CBV] #23 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.289 | FDAX1226.EUREX [CBV] 150000 Volume #29 | Reloading chart. 2026-10-12 02:32:52.289 | FDAX1226.EUREX [CBV] 150000 Volume #29 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.289 | FDAX1226.EUREX [CBV] 150000 Volume #29 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.311 | FDAX1226.EUREX 8 Range #12 | Reloading chart. 2026-10-12 02:32:52.330 | FDAX1226.EUREX [CBV] 3 Min #2 | Reloading chart. 2026-10-12 02:32:52.330 | FDAX1226.EUREX [CBV] 3 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.330 | FDAX1226.EUREX [CBV] 3 Min #2 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.362 | FDAX1226.EUREX [CBV] #20 | Reloading chart. 2026-10-12 02:32:52.362 | FDAX1226.EUREX [CBV] #20 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.362 | FDAX1226.EUREX [CBV] #20 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.389 | FDAX1226.EUREX [CBV] #24 | Reloading chart. 2026-10-12 02:32:52.389 | FDAX1226.EUREX [CBV] #24 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.389 | FDAX1226.EUREX [CBV] #24 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.421 | ESM25_FUT_CME Renko 5t #6 | Reloading chart. 2026-10-12 02:32:52.466 | FDAX1226.EUREX 5000 Volume #30 | Reloading chart. 2026-10-12 02:32:52.492 | Loading market depth data. 2026-10-12 02:32:52.653 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 00:00:00.000000 to 00:00:00.000000. 2026-10-12 02:32:52.665 | FDAX1226.EUREX [CBV] 150 Volume #26 | Reloading chart. 2026-10-12 02:32:52.665 | FDAX1226.EUREX [CBV] 150 Volume #26 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:52.665 | FDAX1226.EUREX [CBV] 150 Volume #26 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:52.684 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 00:00:00.000000 to 00:00:00.000000. 2026-10-12 02:32:52.705 | Loading market depth data. 2026-10-12 02:32:52.804 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 00:00:00.000000 to 00:00:00.000000. 2026-10-12 02:32:52.827 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 00:00:00.000000 to 00:00:00.000000. 2026-10-12 02:32:52.879 | ESM26_FUT_CME 1800 Volume #32 | Reloading chart. 2026-10-12 02:32:52.888 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 09:00:00.000000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:52.894 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 00:00:00.000000 to 00:00:00.000000. 2026-10-12 02:32:52.942 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 00:00:00.000000 to 00:00:00.000000. 2026-10-12 02:32:52.943 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 09:00:00.000000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:52.965 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 09:00:00.000000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:52.979 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 09:00:00.000000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:53.024 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 09:02:25.279385 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:53.061 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 09:00:00.000000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:53.104 | FDAX1226.EUREX 10 Range #1 | Reloading chart. 2026-10-12 02:32:53.160 | Loading market depth data. 2026-10-12 02:32:53.293 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:53.313 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:53.334 | FDAX1226.EUREX 10 Range #4 | Reloading chart. 2026-10-12 02:32:53.340 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:53.354 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:53.393 | Loading market depth data. 2026-10-12 02:32:53.508 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 08:06:03.976286 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:53.539 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:53.552 | FDAX1226.EUREX [CBV] 1 Min #10 | Reloading chart. 2026-10-12 02:32:53.552 | FDAX1226.EUREX [CBV] 1 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:53.552 | FDAX1226.EUREX [CBV] 1 Min #10 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:53.566 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:53.575 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:53.605 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:53.623 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:53.629 | Loading market depth data. 2026-10-12 02:32:53.779 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:53.788 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 08:06:03.976286 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:53.813 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:53.846 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:53.846 | FDAX1226.EUREX [CBV] 150 Volume #15 | Reloading chart. 2026-10-12 02:32:53.846 | FDAX1226.EUREX [CBV] 150 Volume #15 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:53.846 | FDAX1226.EUREX [CBV] 150 Volume #15 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:53.850 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:53.866 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:53.899 | Loading market depth data. 2026-10-12 02:32:54.009 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 07:34:15.788000 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:54.042 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:54.068 | FDAX1226.EUREX [CBV] 1 Min #25 | Reloading chart. 2026-10-12 02:32:54.068 | FDAX1226.EUREX [CBV] 1 Min #25 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:54.068 | FDAX1226.EUREX [CBV] 1 Min #25 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:54.068 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:54.075 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:54.104 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:54.123 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:54.142 | Loading market depth data. 2026-10-12 02:32:54.283 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 08:06:03.976286 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:54.287 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:54.320 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:54.335 | FDAX1226.EUREX [CBV] 1 Min #28 | Reloading chart. 2026-10-12 02:32:54.335 | FDAX1226.EUREX [CBV] 1 Min #28 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:54.335 | FDAX1226.EUREX [CBV] 1 Min #28 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:54.338 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:54.352 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:54.368 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:54.409 | Loading market depth data. 2026-10-12 02:32:54.503 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 07:34:15.788000 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:54.538 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:54.553 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:54.565 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:54.591 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:54.595 | FDAX1226.EUREX [CBV] 150 Volume #31 | Reloading chart. 2026-10-12 02:32:54.595 | FDAX1226.EUREX [CBV] 150 Volume #31 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:54.595 | FDAX1226.EUREX [CBV] 150 Volume #31 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:54.610 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:54.651 | Loading market depth data. 2026-10-12 02:32:54.764 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 07:34:15.788000 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:54.800 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:54.822 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:54.831 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:54.847 | FDAX1226.EUREX [CBV] 1 Min #33 | Reloading chart. 2026-10-12 02:32:54.847 | FDAX1226.EUREX [CBV] 1 Min #33 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:54.847 | FDAX1226.EUREX [CBV] 1 Min #33 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:54.859 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:54.876 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:54.920 | Loading market depth data. 2026-10-12 02:32:55.013 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 08:06:03.976286 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:55.059 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:55.070 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:55.082 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:55.107 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:55.108 | FDAX1226.EUREX [CBV] 150 Volume #16 | Reloading chart. 2026-10-12 02:32:55.108 | FDAX1226.EUREX [CBV] 150 Volume #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2026-10-12 02:32:55.108 | FDAX1226.EUREX [CBV] 150 Volume #16 | There are no continuous futures contract symbols. Loading data normally. 2026-10-12 02:32:55.124 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:55.166 | Loading market depth data. 2026-10-12 02:32:55.274 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 07:34:15.788000 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:55.314 | Loaded depth data records for FDAX1226.EUREX 2026-09-18 from 2026-09-18 08:58:36.788000 to 2026-09-18 13:16:49.184742. 2026-10-12 02:32:55.332 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:55.342 | Loaded depth data records for FDAX1226.EUREX 2026-09-21 from 2026-09-21 08:45:00.606000 to 2026-09-21 14:42:55.005364. 2026-10-12 02:32:55.361 | Loaded depth data records for FDAX1226.EUREX 2026-09-22 from 2026-09-22 08:22:29.592000 to 2026-09-22 14:54:06.808674. 2026-10-12 02:32:55.368 | FDAX1226.EUREX [CBV-D] Daily #5 | Chart data loading complete. 2026-10-12 02:32:55.369 | FDAX1226.EUREX #18 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.369 | FDAX1226.EUREX #18 | Chart data loading complete. 2026-10-12 02:32:55.376 | Loaded depth data records for FDAX1226.EUREX 2026-09-23 from 2026-09-23 08:30:43.762000 to 2026-09-23 13:44:27.303468. 2026-10-12 02:32:55.423 | Loaded depth data records for FDAX1226.EUREX 2026-09-24 from 2026-09-24 07:34:15.788000 to 2026-09-24 14:53:47.795352. 2026-10-12 02:32:55.423 | FDAX1226.EUREX [CBV-D] 1 Day #11 | Chart data loading complete. 2026-10-12 02:32:55.430 | FDAX1226.EUREX [CBV-D] 540000 Volume #13 | Chart data loading complete. 2026-10-12 02:32:55.434 | FDAX1226.EUREX [CBV-D] 1500 Volume #21 | Chart data loading complete. 2026-10-12 02:32:55.443 | FDAX1226.EUREX [CBV-D] #7 | Chart data loading complete. 2026-10-12 02:32:55.454 | FDAX1226.EUREX [CBV-D] #8 | Chart data loading complete. 2026-10-12 02:32:55.457 | Loaded depth data records for FDAX1226.EUREX 2026-09-25 from 2026-09-25 08:03:53.240000 to 2026-09-25 10:05:42.678640. 2026-10-12 02:32:55.465 | FDAX1226.EUREX [CBV-D] #14 | Chart data loading complete. 2026-10-12 02:32:55.480 | ESM26_FUT_CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.481 | ESM26_FUT_CME #9 | Chart data loading complete. 2026-10-12 02:32:55.487 | HD Request # 54 | Downloading Intraday chart data for ESM24_FUT_CME to the file ESM24_FUT_CME.scid. Service: cme 2026-10-12 02:32:55.487 | HD Request # 54 | Download start date-time: 2024-06-21 09:29:59.000000. File last date-time: 2024-06-21 09:29:59.522000 2026-10-12 02:32:55.487 | HD Request # 54 | Using server: ds37.sierracharts.com port 10149 2026-10-12 02:32:55.487 | Socket (2) | Creating socket. 2026-10-12 02:32:55.487 | Socket (2) | New receive buffer size: 0 2026-10-12 02:32:55.487 | Socket (2) | Connecting to IP: 4.8.175.92. 2026-10-12 02:32:55.489 | HD Request # 55 | Downloading Historical Daily chart data for ESM24_FUT_CME. Starting date: 2024-06-18. Service: sc_futures_direct.dtc.trading 2026-10-12 02:32:55.490 | FDAX1226.EUREX [CBV-D] #19 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.493 | FDAX1226.EUREX [CBV-D] #19 | Chart data loading complete. 2026-10-12 02:32:55.504 | FDAX1226.EUREX [CBV-D] #3 | Chart data loading complete. 2026-10-12 02:32:55.512 | FDAX1226.EUREX [CBV-D] #17 | Chart data loading complete. 2026-10-12 02:32:55.516 | Chart #27 has tagged chart #9 for full recalculation. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:32:55.516 | FDAX1226.EUREX [CBV-D] 5000 Volume #27 | Chart data loading complete. 2026-10-12 02:32:55.526 | FDAX1226.EUREX [CBV-D] #23 | Chart data loading complete. 2026-10-12 02:32:55.528 | FDAX1226.EUREX [CBV-D] 150000 Volume #29 | Chart data loading complete. 2026-10-12 02:32:55.530 | Chart #2 has tagged chart #27 for full recalculation. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:32:55.530 | Chart #2 has tagged chart #9 for full recalculation. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:32:55.530 | FDAX1226.EUREX [CBV-D] 3 Min #2 | Chart data loading complete. 2026-10-12 02:32:55.544 | Chart #12 has tagged chart #9 for full recalculation. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:32:55.544 | FDAX1226.EUREX 8 Range #12 | Chart data loading complete. 2026-10-12 02:32:55.552 | FDAX1226.EUREX [CBV-D] #20 | Chart data loading complete. 2026-10-12 02:32:55.560 | FDAX1226.EUREX [CBV-D] #24 | Chart data loading complete. 2026-10-12 02:32:55.579 | FDAX1226.EUREX 5000 Volume #30 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.583 | FDAX1226.EUREX 5000 Volume #30 | Chart data loading complete. 2026-10-12 02:32:55.589 | FDAX1226.EUREX [CBV-D] 150 Volume #26 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.595 | FDAX1226.EUREX [CBV-D] 150 Volume #26 | Chart data loading complete. 2026-10-12 02:32:55.611 | FDAX1226.EUREX 10 Range #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.674 | FDAX1226.EUREX 10 Range #1 | Chart data loading complete. 2026-10-12 02:32:55.683 | FDAX1226.EUREX 10 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.714 | HD Request # 54 | Setting DTC encoding to Binary VLS 2026-10-12 02:32:55.714 | HD Request # 54 | Sending historical data logon request message. 2026-10-12 02:32:55.741 | FDAX1226.EUREX 10 Range #4 | Chart data loading complete. 2026-10-12 02:32:55.746 | FDAX1226.EUREX [CBV-D] 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.771 | FDAX1226.EUREX [CBV-D] 1 Min #10 | Chart data loading complete. 2026-10-12 02:32:55.778 | FDAX1226.EUREX [CBV-D] 150 Volume #15 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.783 | FDAX1226.EUREX [CBV-D] 150 Volume #15 | Chart data loading complete. 2026-10-12 02:32:55.788 | FDAX1226.EUREX [CBV-D] 1 Min #25 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.820 | FDAX1226.EUREX [CBV-D] 1 Min #25 | Chart data loading complete. 2026-10-12 02:32:55.826 | FDAX1226.EUREX [CBV-D] 1 Min #28 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.853 | FDAX1226.EUREX [CBV-D] 1 Min #28 | Chart data loading complete. 2026-10-12 02:32:55.857 | FDAX1226.EUREX [CBV-D] 150 Volume #31 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.863 | FDAX1226.EUREX [CBV-D] 150 Volume #31 | Chart data loading complete. 2026-10-12 02:32:55.869 | FDAX1226.EUREX [CBV-D] 1 Min #33 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.891 | HD Request # 54 | Requesting Intraday data. Start date-time: 2024-06-21 09:29:59. Record interval: 0. Symbol: ESM24 2026-10-12 02:32:55.903 | FDAX1226.EUREX [CBV-D] 1 Min #33 | Chart data loading complete. 2026-10-12 02:32:55.909 | FDAX1226.EUREX [CBV-D] 150 Volume #16 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:55.942 | FDAX1226.EUREX [CBV-D] 150 Volume #16 | Chart data loading complete. 2026-10-12 02:32:55.979 | ESM26_FUT_CME 1800 Volume #32 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:56.009 | HD Request # 54 | Decompressing data. 2026-10-12 02:32:56.068 | ESM26_FUT_CME 1800 Volume #32 | Chart data loading complete. 2026-10-12 02:32:56.121 | HD Request # 54 | Receiving Intraday data for ESM24_FUT_CME starting at 2024-06-21 09:29:59.058000 2026-10-12 02:32:56.121 | Socket (2) | CloseSocket call. 2026-10-12 02:32:56.121 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-10-12 02:32:56.121 | Historical data download thread signaled to stop. 2026-10-12 02:32:56.121 | HD Request # 54 | Received 12 Intraday data records from 2024-06-21 09:29:59.058000 to 2024-06-21 09:29:59.522000 (0.5 seconds. Delay: 2.3 years) and wrote 0 records for ESM24_FUT_CME 2026-10-12 02:32:56.122 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2024-06-21 13:29:59.522000 2026-10-12 02:32:56.122 | HD Request # 54 | Completion time: 1s. 2026-10-12 02:32:56.122 | HD Request # 54 | Intraday data download complete for ESM24_FUT_CME. Unique request ID: 99 2026-10-12 02:32:56.122 | Removing historical data download ID 99. 2026-10-12 02:32:56.122 | Real-time Intraday chart data file updates started for ESM24_FUT_CME 2026-10-12 02:32:56.122 | Intraday chart data file opened for ESM24_FUT_CME 2026-10-12 02:32:56.122 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2026-10-12 02:32:56.122 | 2026-10-12 02:32:56.122 | No download requests in the queue to start downloads for. 2026-10-12 02:32:56.196 | ESM26_FUT_CME 1800 Volume #32 | Reloading chart. 2026-10-12 02:32:56.230 | Socket (2) | Socket gracefully closed by remote side. 2026-10-12 02:32:56.230 | Socket (2) | Closed. 2026-10-12 02:32:56.634 | HD Request # 55 | Requesting historical Daily data for ESM24 starting at 2024-06-17. SC External HD service. 2026-10-12 02:32:56.897 | HD Request # 55 | Receiving historical Daily data for ESM24_FUT_CME starting at 2024-06-18. 2026-10-12 02:32:56.897 | HD Request # 55 | Writing historical Daily data to the file ESM24_FUT_CME.dly. 2026-10-12 02:32:56.899 | HD Request # 55 | Bytes received: 229 2026-10-12 02:32:56.899 | HD Request # 55 | Received 4 Daily data records from 2024-06-18 00:00:00 to 2024-06-21 00:00:00 (4.0 days) and wrote 3 records for ESM24_FUT_CME 2026-10-12 02:32:56.899 | HD Request # 55 | Completion time: 1s. 2026-10-12 02:32:56.899 | HD Request # 55 | Daily data download complete for ESM24_FUT_CME. Unique request ID: 100 2026-10-12 02:32:56.899 | Removing historical data download ID 100. 2026-10-12 02:32:56.899 | 2026-10-12 02:32:56.899 | No download requests in the queue to start downloads for. 2026-10-12 02:32:57.031 | ESM24_FUT_CME [CBV] 10 Sec #22 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-12 02:32:57.032 | ESM24_FUT_CME [CBV] 10 Sec #22 | Reloading chart. | Number times message added: 1 2026-10-12 02:32:58.267 | ESM26_FUT_CME[M] 1800 Volume #32 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:32:58.382 | ESM26_FUT_CME[M] 1800 Volume #32 | Chart data loading complete. 2026-10-12 02:33:01.552 | Loading market depth data. 2026-10-12 02:33:01.553 | ESM24_FUT_CME [CBV][M] 10 Sec #22 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 02:33:01.617 | ESM24_FUT_CME [CBV][M] 10 Sec #22 | Chart data loading complete. 2026-10-12 02:33:04.291 | File >> Disconnect selected. 2026-10-12 02:33:04.330 | Teton CME Routing | Waiting for socket receive thread to end 2026-10-12 02:33:04.331 | DTC Client socket (1) | CloseSocket call. 2026-10-12 02:33:04.331 | DTC Client socket (1) | Max send buffers used during socket life: 3 2026-10-12 02:33:04.331 | DTC Client socket (1) | Max send buffer size during socket life: 326 2026-10-12 02:33:04.331 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-10-12 02:33:04.332 | Denali Data Feed | Waiting for socket receive thread to end 2026-10-12 02:33:04.333 | DTC Client socket (3) | CloseSocket call. 2026-10-12 02:33:04.333 | DTC Client socket (3) | Max send buffers used during socket life: 3 2026-10-12 02:33:04.333 | DTC Client socket (3) | Max send buffer size during socket life: 280 2026-10-12 02:33:04.333 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-10-12 02:33:04.333 | Denali Data Feed | Disconnected from the server. 2026-10-12 02:33:04.333 | Teton CME Routing | Disconnected. 2026-10-12 02:33:04.436 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-10-12 02:33:04.436 | DTC Client socket (1) | Closed. 2026-10-12 02:33:04.442 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-10-12 02:33:04.442 | DTC Client socket (3) | Closed. 2026-10-12 02:33:15.322 | ESM25_FUT_CME[M] Renko 5t #6 | Chart data loading complete. 2026-10-12 02:33:15.354 | FDAX1226.EUREX [CBV-D] 5000 Volume #27 | Performing a full recalculation because it has been tagged. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:33:15.354 | Chart #27 has tagged chart #9 for full recalculation. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:33:15.601 | ESM26_FUT_CME[M] #9 | Performing a full recalculation because it has been tagged. Chartbook: DAX FDAXU26-EUREX.Cht 2026-10-12 02:33:18.159 | 2026-10-12 02:33:18.159 | Teton CME Routing | Firm: AMP 2026-10-12 02:33:18.159 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2026-10-12 02:33:18.160 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-10-12 02:33:18.161 | DTC Client socket (1) | New receive buffer size: 0 2026-10-12 02:33:18.161 | DTC Client socket (1) | Connecting to IP: 216.200.108.154. 2026-10-12 02:33:18.265 | Teton CME Routing | Network connection to server complete. 2026-10-12 02:33:18.265 | Teton CME Routing | Starting socket receive thread. 2026-10-12 02:33:18.265 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-10-12 02:33:18.592 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-10-12 02:33:18.592 | Teton CME Routing | Sending logon request message. 2026-10-12 02:33:18.750 | Teton CME Routing | Received logon response. 2026-10-12 02:33:18.750 | Teton CME Routing | Server Name: SC DTC Server. Build=58073. 2026-10-12 02:33:18.750 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-10-12 02:33:18.750 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-10-12 02:33:18.750 | Teton CME Routing | Trading is supported. 2026-10-12 02:33:18.750 | Teton CME Routing | Order cancel and replace is supported. 2026-10-12 02:33:18.750 | Teton CME Routing | OCO Orders supported. 2026-10-12 02:33:18.750 | Teton CME Routing | Bracket Orders supported. 2026-10-12 02:33:18.750 | Teton CME Routing | MarketDepthIsSupported: 1 2026-10-12 02:33:18.750 | Teton CME Routing | Connection to server complete. 2026-10-12 02:33:18.750 | No download requests in the queue to start downloads for. | Number times message added: 3 2026-10-12 02:33:18.750 | Updated verified funded futures trading account ending date to: 2026-11-11 06:33:18 2026-10-12 02:33:18.783 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-10-12 02:33:18.784 | Using symbol data fast lookup vector 2026-10-12 02:33:18.784 | Teton CME Routing | Starting real-time market data updates for: FDAX1226.EUREX. ID: 1 2026-10-12 02:33:18.784 | Teton CME Routing | Subscribing to streaming market data in the service client is not supported. Symbol: FDAX1226.EUREX 2026-10-12 02:33:18.784 | Teton CME Routing | Requesting security definition data for: FDAX1226.EUREX. ID: 1 2026-10-12 02:33:18.784 | No historical data client is currently set to download historical Intraday data for FDAX1226.EUREX. 2026-10-12 02:33:18.784 | Real-time Intraday chart data file updates started for FDAX1226.EUREX 2026-10-12 02:33:18.784 | Intraday chart data file opened for FDAX1226.EUREX 2026-10-12 02:33:18.785 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-09-30 07:05:08.554058 2026-10-12 02:33:18.841 | Mapping ESM26_FUT_CME to ESM26. Service code: cme 2026-10-12 02:33:18.841 | Denali Data Feed | Starting real-time market data updates for: ESM26_FUT_CME (ESM26). ID: 2 Service code: cme 2026-10-12 02:33:18.842 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 2026-10-12 02:33:18.842 | Denali Data Feed | Requesting security definition data for: ESM26_FUT_CME (ESM26). ID: 2 2026-10-12 02:33:18.842 | Added historical Intraday data request for ESM26_FUT_CME to the queue. 2026-10-12 02:33:18.842 | Intraday data recording state for symbol ESM26_FUT_CME is set to download 'Pending'. 2026-10-12 02:33:18.842 | Triggering next historical data download in queue. 2026-10-12 02:33:18.843 | Delaying start of download for ESM26_FUT_CME. 2026-10-12 02:33:18.843 | Mapping ESM25_FUT_CME to ESM25. Service code: cme 2026-10-12 02:33:18.843 | Denali Data Feed | Starting real-time market data updates for: ESM25_FUT_CME (ESM25). ID: 3 Service code: cme 2026-10-12 02:33:18.843 | Denali Data Feed | Requesting security definition data for: ESM25_FUT_CME (ESM25). ID: 3 2026-10-12 02:33:18.843 | Added historical Intraday data request for ESM25_FUT_CME to the queue. 2026-10-12 02:33:18.843 | Intraday data recording state for symbol ESM25_FUT_CME is set to download 'Pending'. 2026-10-12 02:33:18.843 | Triggering next historical data download in queue. 2026-10-12 02:33:18.847 | Requesting market depth updates for: FDAX1226.EUREX if supported. NumLevels=1400 2026-10-12 02:33:18.847 | Separate subscription for market depth updates not supported. FDAX1226.EUREX 2026-10-12 02:33:18.888 | Updated verified funded futures trading account ending date to: 2026-11-11 06:33:18 2026-10-12 02:33:18.888 | Teton CME Routing | Security Definition request has been rejected. Reason: Unsupported symbol: FDAX1226.EUREX. ID = 1 2026-10-12 02:33:18.904 | DTC Client socket (2) | Creating socket. 2026-10-12 02:33:18.904 | DTC Client socket (2) | New receive buffer size: 0 2026-10-12 02:33:18.904 | DTC Client socket (2) | Connecting to IP: 64.152.155.17. 2026-10-12 02:33:18.987 | Mapping ESM24_FUT_CME to ESM24. Service code: cme 2026-10-12 02:33:18.987 | Denali Data Feed | Starting real-time market data updates for: ESM24_FUT_CME (ESM24). ID: 4 Service code: cme 2026-10-12 02:33:18.987 | Denali Data Feed | Requesting security definition data for: ESM24_FUT_CME (ESM24). ID: 4 2026-10-12 02:33:18.987 | Requesting market depth updates for: ESM24_FUT_CME if supported. NumLevels=100 2026-10-12 02:33:18.988 | Added historical Intraday data request for ESM24_FUT_CME to the queue. 2026-10-12 02:33:18.988 | Intraday data recording state for symbol ESM24_FUT_CME is set to download 'Pending'. 2026-10-12 02:33:18.988 | Triggering next historical data download in queue. 2026-10-12 02:33:18.997 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM26_FUT_CME 2026-10-12 02:33:18.997 | Teton CME Routing | Setting external service identifier for symbol ESM26_FUT_CME to 275 2026-10-12 02:33:18.997 | Teton CME Routing | Received security definition for symbol ESM26_FUT_CME 2026-10-12 02:33:18.997 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM25_FUT_CME 2026-10-12 02:33:18.997 | Teton CME Routing | Setting external service identifier for symbol ESM25_FUT_CME to 451 2026-10-12 02:33:18.997 | Teton CME Routing | Received security definition for symbol ESM25_FUT_CME 2026-10-12 02:33:19.004 | Denali Data Feed | Network connection to server complete. 2026-10-12 02:33:19.004 | Denali Data Feed | Starting socket receive thread. 2026-10-12 02:33:19.004 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-10-12 02:33:19.103 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM24_FUT_CME 2026-10-12 02:33:19.103 | Teton CME Routing | Setting external service identifier for symbol ESM24_FUT_CME to 392 2026-10-12 02:33:19.103 | Teton CME Routing | Received security definition for symbol ESM24_FUT_CME 2026-10-12 02:33:19.113 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-10-12 02:33:19.113 | Denali Data Feed | Sending logon request message. 2026-10-12 02:33:19.675 | Denali Data Feed | Received logon response. 2026-10-12 02:33:19.675 | Denali Data Feed | Server Name: SC Realtime Server. 2026-10-12 02:33:19.675 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-10-12 02:33:19.675 | Denali Data Feed | Successfully connected. 2026-10-12 02:33:19.675 | Denali Data Feed | Trading is not supported. 2026-10-12 02:33:19.675 | Denali Data Feed | MarketDepthIsSupported: 1 2026-10-12 02:33:19.675 | Denali Data Feed | Restarting real-time data updates for symbol: ESM24_FUT_CME -> ESM24. Market Depth data restarted. 2026-10-12 02:33:19.675 | Denali Data Feed | Restarting real-time data updates for symbol: ESM25_FUT_CME -> ESM25 2026-10-12 02:33:19.675 | Denali Data Feed | Restarting real-time data updates for symbol: ESM26_FUT_CME -> ESM26 2026-10-12 02:33:19.863 | Denali Data Feed | Clearing market depth for ESM24_FUT_CME 2026-10-12 02:33:19.863 | Enabling compression for file: C:\SierraChart\Data\MarketDepthData\ESM24_FUT_CME.2026-10-12.depth 2026-10-12 02:33:19.864 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESM24_FUT_CME.2026-10-12.depth 2026-10-12 02:33:19.864 | Denali Data Feed | Real-time data for symbol ESM24_FUT_CME is currently unavailable. 2026-10-12 02:33:19.864 | Denali Data Feed | Received security definition for symbol ESM24_FUT_CME 2026-10-12 02:33:19.864 | Denali Data Feed | Real-time data for symbol ESM25_FUT_CME is currently unavailable. 2026-10-12 02:33:19.864 | Denali Data Feed | Received security definition for symbol ESM25_FUT_CME 2026-10-12 02:33:19.864 | Denali Data Feed | Real-time data for symbol ESM26_FUT_CME is currently unavailable. 2026-10-12 02:33:19.864 | Denali Data Feed | Received security definition for symbol ESM26_FUT_CME 2026-10-12 02:33:23.758 | Requesting market depth updates for: ESM26_FUT_CME if supported. NumLevels=100 2026-10-12 02:33:23.958 | Denali Data Feed | Clearing market depth for ESM26_FUT_CME 2026-10-12 02:33:24.118 | HD Request # 56 | Downloading Intraday chart data for ESM26_FUT_CME to the file ESM26_FUT_CME.scid. Service: cme 2026-10-12 02:33:24.119 | HD Request # 56 | Download start date-time: 2026-06-18 09:29:59.000000. File last date-time: 2026-06-18 09:29:59.407000 2026-10-12 02:33:24.119 | HD Request # 56 | Using server: ds28.sierracharts.com port 10150 2026-10-12 02:33:24.119 | Socket (3) | Creating socket. 2026-10-12 02:33:24.119 | Socket (3) | New receive buffer size: 0 2026-10-12 02:33:24.119 | Socket (3) | Connecting to IP: 67.214.125.5. 2026-10-12 02:33:24.360 | HD Request # 56 | Setting DTC encoding to Binary VLS 2026-10-12 02:33:24.360 | HD Request # 56 | Sending historical data logon request message. 2026-10-12 02:33:24.501 | HD Request # 56 | Requesting Intraday data. Start date-time: 2026-06-18 09:29:59. Record interval: 0. Symbol: ESM26 2026-10-12 02:33:24.611 | HD Request # 56 | Decompressing data. 2026-10-12 02:33:24.720 | HD Request # 56 | Receiving Intraday data for ESM26_FUT_CME starting at 2026-06-18 09:29:59.122000 2026-10-12 02:33:24.720 | Socket (3) | CloseSocket call. 2026-10-12 02:33:24.720 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-12 02:33:24.721 | Historical data download thread signaled to stop. 2026-10-12 02:33:24.721 | HD Request # 56 | Received 3 Intraday data records from 2026-06-18 09:29:59.122000 to 2026-06-18 09:29:59.407000 (0.3 seconds. Delay: 115.7 days) and wrote 0 records for ESM26_FUT_CME 2026-10-12 02:33:24.721 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2026-06-18 13:29:59.407000 2026-10-12 02:33:24.721 | HD Request # 56 | Completion time: 0s. 2026-10-12 02:33:24.721 | HD Request # 56 | Intraday data download complete for ESM26_FUT_CME. Unique request ID: 101 2026-10-12 02:33:24.721 | Removing historical data download ID 101. 2026-10-12 02:33:24.721 | Real-time Intraday chart data file updates started for ESM26_FUT_CME 2026-10-12 02:33:24.721 | Intraday chart data file opened for ESM26_FUT_CME 2026-10-12 02:33:24.721 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2026-10-12 02:33:24.721 | 2026-10-12 02:33:24.721 | Triggering next historical data download in queue. 2026-10-12 02:33:24.721 | HD Request # 57 | Downloading Intraday chart data for ESM25_FUT_CME to the file ESM25_FUT_CME.scid. Service: cme 2026-10-12 02:33:24.721 | HD Request # 57 | Download start date-time: 2025-06-20 09:29:59.000000. File last date-time: 2025-06-20 09:29:59.576000 2026-10-12 02:33:24.721 | HD Request # 57 | Using server: ds32.sierracharts.com port 10149 2026-10-12 02:33:24.722 | Socket (4) | Creating socket. 2026-10-12 02:33:24.722 | Socket (4) | New receive buffer size: 0 2026-10-12 02:33:24.722 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-10-12 02:33:24.829 | Socket (3) | Socket gracefully closed by remote side. 2026-10-12 02:33:24.829 | Socket (3) | Closed. 2026-10-12 02:33:24.942 | HD Request # 57 | Setting DTC encoding to Binary VLS 2026-10-12 02:33:24.942 | HD Request # 57 | Sending historical data logon request message. 2026-10-12 02:33:25.084 | HD Request # 57 | Requesting Intraday data. Start date-time: 2025-06-20 09:29:59. Record interval: 0. Symbol: ESM25 2026-10-12 02:33:25.195 | HD Request # 57 | Decompressing data. 2026-10-12 02:33:25.306 | HD Request # 57 | Receiving Intraday data for ESM25_FUT_CME starting at 2025-06-20 09:29:59.576000 2026-10-12 02:33:25.306 | Socket (4) | CloseSocket call. 2026-10-12 02:33:25.306 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-10-12 02:33:25.307 | Historical data download thread signaled to stop. 2026-10-12 02:33:25.307 | HD Request # 57 | Received 1 Intraday data record from 2025-06-20 09:29:59.576000 to 2025-06-20 09:29:59.576000 (0.0 seconds. Delay: 478.7 days) and wrote 0 records for ESM25_FUT_CME 2026-10-12 02:33:25.307 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2025-06-20 13:29:59.576000 2026-10-12 02:33:25.307 | HD Request # 57 | Completion time: 1s. 2026-10-12 02:33:25.307 | HD Request # 57 | Intraday data download complete for ESM25_FUT_CME. Unique request ID: 102 2026-10-12 02:33:25.307 | Removing historical data download ID 102. 2026-10-12 02:33:25.307 | Real-time Intraday chart data file updates started for ESM25_FUT_CME 2026-10-12 02:33:25.307 | Intraday chart data file opened for ESM25_FUT_CME 2026-10-12 02:33:25.307 | HD Request # 57 | Enabling Intraday chart updating for symbol. 2026-10-12 02:33:25.307 | 2026-10-12 02:33:25.307 | Triggering next historical data download in queue. 2026-10-12 02:33:25.307 | HD Request # 58 | Downloading Intraday chart data for ESM24_FUT_CME to the file ESM24_FUT_CME.scid. Service: cme 2026-10-12 02:33:25.307 | HD Request # 58 | Download start date-time: 2024-06-21 09:29:59.000000. File last date-time: 2024-06-21 09:29:59.522000 2026-10-12 02:33:25.307 | HD Request # 58 | Using server: ds37.sierracharts.com port 10150 2026-10-12 02:33:25.307 | Socket (3) | Creating socket. 2026-10-12 02:33:25.307 | Socket (3) | New receive buffer size: 0 2026-10-12 02:33:25.307 | Socket (3) | Connecting to IP: 4.8.175.92. 2026-10-12 02:33:25.418 | Socket (4) | Socket gracefully closed by remote side. 2026-10-12 02:33:25.418 | Socket (4) | Closed. 2026-10-12 02:33:25.527 | HD Request # 58 | Setting DTC encoding to Binary VLS 2026-10-12 02:33:25.527 | HD Request # 58 | Sending historical data logon request message. 2026-10-12 02:33:25.696 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-06-21 09:29:59. Record interval: 0. Symbol: ESM24 2026-10-12 02:33:25.808 | HD Request # 58 | Decompressing data. 2026-10-12 02:33:25.917 | HD Request # 58 | Receiving Intraday data for ESM24_FUT_CME starting at 2024-06-21 09:29:59.058000 2026-10-12 02:33:25.917 | Socket (3) | CloseSocket call. 2026-10-12 02:33:25.917 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-12 02:33:25.917 | Historical data download thread signaled to stop. 2026-10-12 02:33:25.917 | HD Request # 58 | Received 12 Intraday data records from 2024-06-21 09:29:59.058000 to 2024-06-21 09:29:59.522000 (0.5 seconds. Delay: 2.3 years) and wrote 0 records for ESM24_FUT_CME 2026-10-12 02:33:25.918 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-06-21 13:29:59.522000 2026-10-12 02:33:25.918 | HD Request # 58 | Completion time: 0s. 2026-10-12 02:33:25.918 | HD Request # 58 | Intraday data download complete for ESM24_FUT_CME. Unique request ID: 103 2026-10-12 02:33:25.918 | Removing historical data download ID 103. 2026-10-12 02:33:25.918 | Real-time Intraday chart data file updates started for ESM24_FUT_CME 2026-10-12 02:33:25.918 | Intraday chart data file opened for ESM24_FUT_CME 2026-10-12 02:33:25.918 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2026-10-12 02:33:25.918 | 2026-10-12 02:33:25.918 | No download requests in the queue to start downloads for. 2026-10-12 02:33:26.025 | Socket (3) | Socket gracefully closed by remote side. 2026-10-12 02:33:26.025 | Socket (3) | Closed. |
| [2026-10-12 07:47:06] |
This is the wrong symbol: FDAX1226.EUREX
It should be: FDAXZ26-EUREX Set the chart to the correct symbol. Refer to: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-12 07:47:53
