Date/Time: Thu, 26 Nov 2026 00:56:26 +0000
[Programming Help] - Recompile at every Version??
View Count: 273
| [2026-10-08 10:41:00] |
| User213910 - Posts: 28 |
Hi Sierra Chart team, Do I have to recompile my studies with every pre-release version? I had my studies compiled and working with version 2963, but after updating to 2967, I had to recompile them again. Is there a way to avoid this with future pre-release versions? It would be quite inconvenient to have to recompile the studies after every update. |
| [2026-10-08 12:03:18] |
| User431178 - Posts: 910 |
It's not normally that way. You should read the sticky post at the top of the support board, it is explained. Upcoming Development and Internal Number Precision Improvement Project |
| [2026-10-08 14:45:32] |
As User431178 points out, this is a particular situation. You will definitely have to recompile with each Pre-Release, as these are having specific changes related to changes to double precision values. And again, this is all specifically called out in this thread: Upcoming Development and Internal Number Precision Improvement Project For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
