Date/Time: Thu, 29 Oct 2026 20:56:28 +0000
[Sticky] [Locked] - Upcoming Development and Internal Number Precision Improvement Project
View Count: 14628
[2026-10-14 08:48:01]
Sierra_Chart Engineering - Posts: 25309
Version 2972 has been released as the main release. This has the finalized changes for ACSIL.
ACSIL custom studies need to be be recompiled for this version and higher. If you are distributing custom DLL files to users, then on this page:
https://www.sierrachart.com/UserControlPanel.php?page=SetFileGroupsForCustomStudies
We have added the ability for you to specify a different DLL file based on the version. See the attachment. This should be self-explanatory.
image2026-10-14_044102.png / V - Attached On 2026-10-14 08:46:44 UTC - Size: 8.07 KB - 136 views
[2026-10-19 18:22:54]
Regarding the new Intraday data file format that has built-in compression, this is a very important technical improvement for Sierra Chart because compression is now handled by Sierra Chart in a consistent and high-performance way, and with a high compression ratio. Rather than leaving this to the operating system where compression may not be supported, or may not be enabled.
Date Time Of Last Edit: 2026-10-19 18:24:06
