Date/Time: Sat, 28 Nov 2026 03:04:41 +0000
Market Depth Historical Graph freezed
View Count: 380
| [2026-10-07 17:30:16] |
| Alex Angehrn - Posts: 8 |
Hi, Level 2 data is updating in the DOM, but Market Depth Historical Graph freezes across all charts immediately after connection in version 2957. Best regards, |
| [2026-10-07 17:30:29] |
Please get us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-07 20:28:31] |
see: https://www.sierrachart.com/image.php?Image=1791404658408.png |
| [2026-10-07 20:47:36] |
We are not sure what we are supposed to be looking at in the image you provided. You are only showing the DOM area of the chart, so the "Market Depth Historical Graph" would only have a minimal presence in that area, and if it is displayed, it is buried under what appears to be a Volume Profile and the "DOM Graph". What exactly is the issue that is occurring in the image you provided? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-08 18:36:10] |
Thank you. Issue is, what the vaules of DOM about buy and sell are freezed. Unfortunately they are not actualizied any more. Now idea why, because I havn't anything in graph or studies. |
| [2026-10-08 19:02:21] |
So this is not about the "Market Depth Historical Graph", but rather is about the actual Market Depth displayed in the DOM. Is this correct? It looks like you are connecting to Rithmic and you are on version 2957. If this is correct, then the issue you are having is that you are getting your data from Rithmic, and with regards to the Market Depth in particular, this is due to Rithmic not having updated their DTC Protocol for changes to the Market Depth data that we have made. We know they are working on this, as they have contacted us about it. And we know they are close to having it ready, if not already done with it. You would need to check with Rithmic in order to find out when they will have this resolved. Another solution would be to use our Denali Exchange Data Feed for your data. You do need a live, funded, futures trading account in order to get the CME Group data at the non-professional rates. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges To then setup the data follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
