Date/Time: Sat, 18 May 2024 21:38:27 +0000
Alert Window - click to goto chart
View Count: 924
[2014-11-07 12:25:51] |
ycomp - Posts: 277 |
When I click an alert in the Alert Manager, I'd like to go to the chart. That works. But it goes to the specific time position of the alert. Which means my chart is no longer updating the new data.. it is red not green in the bottom right corner of the chart. I must scroll to the end to see the new data. Is there a way to make it just go to the chart and not change the chart position? |
[2014-11-07 23:05:27] |
The chart will be scrolled to the particular Date-Time where the alert occurred at. There is no way to disable this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
