Date/Time: Tue, 24 Nov 2026 18:17:04 +0000
TNX_CGI display scaling issue
View Count: 372
| [2026-10-05 18:46:59] |
| Fady Hamad - Posts: 12 |
Hello, I am trying to display the U.S. 10-Year Treasury yield in Sierra Chart using the TNX_CGI symbol. I activated CBOE Global Indexes Additional through the Denali Exchange Data Feed, and TNX_CGI is loading correctly. However, the chart is displaying a value such as 53.28, whereas the actual 10-Year Treasury yield should be around 5.3%. I would like the chart to display the yield directly as approximately 5.328% rather than 53.28. In Chart Settings → Symbol, both the Real-Time Price Multiplier and Historical Price Multiplier are currently set to 1. Could you please tell me the correct Sierra Chart setting to display TNX_CGI with the proper decimal scaling? |
| [2026-10-05 19:12:52] |
Moreover, I can see that the data feed is lagging and not as fast as I it should be. The percent changes is lagging and becomes completely stuck. Kindly assist. |
| [2026-10-05 21:36:07] |
| John - SC Support - Posts: 48643 |
The data displays as values like "53.28" as that is the way the data is specified by the CBOE. You can view the information for the symbol on their website at the following link: https://www.cboe.com/us/indices/dashboard/tnx/ If you want to change the way the prices are displayed, then you will need to change the "Real-Time Price Multiplier" and the "Historical Price Multiplier". Refer to the following and the item below it (note the information about also changing the Tick Size and Price Display Format): Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) This index updates every 10 seconds. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-05 22:00:00] |
My chart is completely stuck. it stopped on Monday the 15th of October 2026 at 08:20:01 and never moved. I tried everything but its still stuck and not updating. Any ideas please? Thank you. |
| [2026-10-06 12:39:10] |
What is the symbol of the chart? Please go through the items at the following link: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-06 13:22:04] |
Hi John, Symbol is TNX_CGI. Which is for the US10Y (correct me if I am wrong). I activated CBOE Global Indexes Additional through the Denali Exchange Data Feed but my chart stopped on Monday the 15th of October 2026 at 08:20:01 and never moved. I have tried every single trick I know about but it doesn't want to load live data. I have been working on this and trying to troubleshoot it for almost 6 hours straight but no luck. Please please help. |
| [2026-10-06 15:53:55] |
We are not seeing any issues with the data for this symbol. And yes, you do have the correct exchange active. Did you go through the items at the link we referenced above? In particular, are your Session Times set properly? If you select "Edit >> Delete All Data and Download", do you get data up to the current time? Does the data then start flowing, or does it stay stuck at the time that the data downloaded to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-06 16:08:48] |
Dear John, Session times is 100% correct. Delete All Data and Download didn't work. Deleting the TNX_CGI file from my Sierra Charts file on my computer and redownloading the same on a new fresh chart didn't work. Translate symbols to current services didn't work. Checking my connection and Denali feed on my Sierra chart didn't work. restarting Sierra charts didn't work. and countless countless other tries and methods didn't work. When you reload the chart its always stays stuck and doesn't move on Monday the 15th of October 2026 at 08:20:01. I have honestly tried everything from my end. Kindly and please help. |
| [2026-10-06 17:15:13] |
Please do the following for us: - Select "Window >> Message Log". - On the Message Log window select "Edit >> Clear Log". - Close or set aside the Message Log. - Go to your chart for TNX_CGI. - With that chart active, select "Edit >> Delete All Data and Download". - After the system finishes downloading the data, get us the information in your Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Also, please get us an image of the chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-08 20:16:16] |
2026-10-08 16:08:52.284 | Software version: 2922 64-bit 2026-10-08 16:08:52.284 | Primary Thread ID: 5752 2026-10-08 16:08:52.284 | Usage end date: 2026-11-24 2026-10-08 16:08:52.284 | Enabled for: Advanced Features 2. 2026-10-08 16:08:52.284 | Enabled for: Sierra Chart Historical Data Service. 2026-10-08 16:08:52.284 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-10-08 16:08:52.284 | Enabled for: Delayed Denali Exchange Data Feed. 2026-10-08 16:08:52.284 | Enabled for exchange2: CME 2026-10-08 16:08:52.284 | Enabled for exchange2: CBOE Global Indexes Additional 2026-10-08 16:08:52.284 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-10-08 16:08:52.284 | Current selected Data/Trading service: SC Data 2026-10-08 16:08:52.284 | Custom symbol settings values: enabled 2026-10-08 16:08:52.284 | Chart Update Interval: 400 2026-10-08 16:08:52.284 | Intraday Data Storage Time Unit: 0 2026-10-08 16:08:52.284 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-10-08 16:08:52.284 | 2026-10-08 20:08:52 Local computer time in UTC 2026-10-08 16:08:52.284 | 2026-10-08 16:08:52 Local computer time in SC Time Zone 2026-10-08 16:08:52.284 | 2026-10-06 06:47:23 Server time in UTC 2026-10-08 16:08:52.284 | Local computer UTC time and Server UTC time difference: 1 seconds. 2026-10-08 16:08:52.284 | Program path: C:\SierraChart\ 2026-10-08 16:08:52.284 | Data Files path: C:\SierraChart\Data\ 2026-10-08 16:08:52.285 | OS Version Number: 10.0 2026-10-08 16:08:52.285 | Locale Setting: C 2026-10-08 16:08:52.285 | Crash reporter started: true 2026-10-08 16:08:52.285 | 2026-10-08 16:09:30.789 | Added historical Intraday data request for TNX_CGI to the queue. 2026-10-08 16:09:30.789 | Intraday data recording state for symbol TNX_CGI is set to download 'Pending'. 2026-10-08 16:09:30.789 | Triggering next historical data download in queue. 2026-10-08 16:09:30.789 | HD Request # 17 | Downloading Intraday chart data for TNX_CGI to the file TNX_CGI.scid. Service: cboe_global_indexes_add.data 2026-10-08 16:09:30.792 | Reloading all charts with filename: TNX_CGI.scid 2026-10-08 16:09:30.793 | HD Request # 17 | Download start date-time: 2026-04-05 16:09:30.000000. File last date-time: 00:00:00.000000 2026-10-08 16:09:30.793 | HD Request # 17 | Using server: ds30.sierracharts.com port 10150 2026-10-08 16:09:30.870 | Socket (3) | Creating socket. 2026-10-08 16:09:30.870 | Socket (3) | New receive buffer size: 0 2026-10-08 16:09:30.870 | Socket (3) | Connecting to IP: 67.214.125.11. 2026-10-08 16:09:31.122 | TNX_CGI/MESZ26-CME [CV-D][M] Renko 10t #6 | Reloading chart. 2026-10-08 16:09:31.122 | TNX_CGI/MESZ26-CME [CV-D][M] Renko 10t #6 | No contract months found for symbol. Unable to build continuous futures contract chart. 2026-10-08 16:09:31.122 | TNX_CGI/MESZ26-CME [CV-D][M] Renko 10t #6 | There are no continuous futures contract symbols. Loading data normally. 2026-10-08 16:09:31.131 | TNX_CGI/MESZ26-CME [CV-D][M] Renko 10t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\TNX_CGI.scid 2026-10-08 16:09:31.133 | TNX_CGI/MESZ26-CME [CV-D][M] Renko 10t #6 | Chart data loading complete. 2026-10-08 16:09:31.311 | HD Request # 17 | Setting DTC encoding to Binary VLS 2026-10-08 16:09:31.311 | HD Request # 17 | Sending historical data logon request message. 2026-10-08 16:09:31.573 | HD Request # 17 | Requesting Intraday data. Start date-time: 2026-04-05 16:09:30. Record interval: 0. Symbol: TNX_CGI 2026-10-08 16:09:31.792 | HD Request # 17 | Decompressing data. 2026-10-08 16:09:32.028 | HD Request # 17 | Receiving Intraday data for TNX_CGI starting at 2026-04-06 08:20:02.333000 2026-10-08 16:09:32.499 | HD Request # 17 | Timestamp of first Intraday data file record written: 2026-04-06 08:20:02.333000. 2026-10-08 16:09:32.772 | TNX_CGI/MESZ26-CME [CV-D][M] Renko 10t #6 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-08 16:09:34.420 | Socket (3) | CloseSocket call. 2026-10-08 16:09:34.420 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-08 16:09:34.451 | Historical data download thread signaled to stop. 2026-10-08 16:09:34.452 | HD Request # 17 | Received 311979 Intraday data records from 2026-04-06 08:20:02.333000 to 2026-10-08 14:59:55.459000 (185.3 days. Delay: 69.6 minutes) and wrote 311979 records for TNX_CGI 2026-10-08 16:09:34.452 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2026-10-08 18:59:55.459000 2026-10-08 16:09:34.452 | HD Request # 17 | Completion time: 4s. 2026-10-08 16:09:34.452 | HD Request # 17 | Intraday data download complete for TNX_CGI. Unique request ID: 22 2026-10-08 16:09:34.452 | Removing historical data download ID 22. 2026-10-08 16:09:34.452 | Real-time Intraday chart data file updates started for TNX_CGI 2026-10-08 16:09:34.452 | Intraday chart data file opened for TNX_CGI 2026-10-08 16:09:34.452 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2026-10-08 16:09:34.452 | 2026-10-08 16:09:34.452 | No download requests in the queue to start downloads for. 2026-10-08 16:09:34.637 | Socket (3) | Socket gracefully closed by remote side. 2026-10-08 16:09:34.637 | Socket (3) | Closed. |
| [2026-10-08 20:20:37] |
https://www.sierrachart.com/image.php?Image=1791490798304.png
| [2026-10-08 20:24:21] |
Dear John, As you can see in the image I have uploaded, the Time in nye now is 16:23 but my chart is stuck on 14:25. |
| [2026-10-08 20:54:20] |
The data for TNX only goes from 08:20 to 14:59:59 Eastern US Time each day. There is no data from 15:00 to 08:19:59. The data in your chart is correct. The last bar actually has data up to 14:59:59. Then there is no new data to be had until tomorrow morning. It you open another chart and set it to be time-based, it will be easier to see that the data goes through to 14:59:59. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
