Date/Time: Sun, 22 Nov 2026 14:14:03 +0000
How to change OHLC values based on cursor position?
View Count: 259
| [2026-10-05 15:42:41] |
| LittleBB - Posts: 19 |
Version: 2957 How can I get the OHLC values to change inside the header as I move my cursor around? I would like the option to have it display tool values instead of the last bar. I found this help article but it doesn't have the desired option. Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line |
| [2026-10-05 21:02:07] |
| John - SC Support - Posts: 48610 |
There are two different window options (three really). These are the "Chart Values Window" and the "Tool Values Window". The "Chart Values Window" only shows the information for the most current bar. If you want to view the information for other bars while you move your crosshairs, then you need to open the "Tool Values Window". Refer to the following: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools The third window option we referenced above is the "Compact Tool Values Window". This works the same as the "Tool Values Window" but is smaller and supplies less overall information. You will find the information for this in the section we linked to above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-05 22:00:51] |
I'm using the compact tool values window as a work around for now. I would still like the option to be available for the Chart Values to show Tool values as an option. I don't like needing to look away from the chart I'm focused on just to see what the OHLC values are. It is especially frustrating when you are trying to draw a rectangle and just need to see the values in order to properly anchor the drawing. |
