Date/Time: Sun, 22 Nov 2026 14:14:03 +0000
Teton CME Routing - Service Connection Timed Out
View Count: 424
[2026-10-05 05:43:44]
User340373 - Posts: 12
I am unable to connect to Teton CME Routing. Sierra Chart remains in “Connecting” status and every connection attempt ends with “Service connection timed out”.
There have been more than 90 failed connection attempts.
I also tested a completely different Internet connection using a mobile hotspot, with exactly the same result.
Current Selected Service: Teton CME Routing
Clearing Firm: AMP
Service Package: 11 - Integrated Advanced (active)
I have sent the complete Message Log using “Send for Analysis”.
Could you please check why my Teton CME Routing connection is timing out?
2026-10-05 01:42:18.842 | Software version: 2933 64-bit
2026-10-05 01:42:18.842 | Primary Thread ID: 16668
2026-10-05 01:42:18.842 | Usage end date: 2026-10-16
2026-10-05 01:42:18.842 | Enabled for: Advanced Features 2.
2026-10-05 01:42:18.842 | Enabled for: Sierra Chart Historical Data Service.
2026-10-05 01:42:18.842 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-10-05 01:42:18.842 | Enabled for: Delayed Denali Exchange Data Feed.
2026-10-05 01:42:18.842 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-10-05 01:42:18.842 | Current selected Data/Trading service: Teton CME Routing
2026-10-05 01:42:18.842 | Custom symbol settings values: enabled
2026-10-05 01:42:18.842 | Chart Update Interval: 500
2026-10-05 01:42:18.842 | Intraday Data Storage Time Unit: 0
2026-10-05 01:42:18.842 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2026-10-05 01:42:18.842 | 2026-10-05 05:42:18 Local computer time in UTC
2026-10-05 01:42:18.842 | 2026-10-05 01:42:18 Local computer time in SC Time Zone
2026-10-05 01:42:18.842 | Program path: C:\SierraChart\
2026-10-05 01:42:18.842 | Data Files path: C:\SierraChart\Data\
2026-10-05 01:42:18.858 | OS Version Number: 10.0
2026-10-05 01:42:18.858 | Locale Setting: C
2026-10-05 01:42:18.858 | Crash reporter started: true
2026-10-05 01:42:24.950 | File >> Disconnect selected.
2026-10-05 01:42:24.950 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:42:24.951 | Teton CME Routing | Disconnected.
2026-10-05 01:42:26.839 |
2026-10-05 01:42:26.841 | Teton CME Routing | ....
2026-10-05 01:43:26.844 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:43:26.844 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:43:26.844 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:43:26.860 | Teton CME Routing | Failed connections: 103
2026-10-05 01:43:26.863 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:43:26.865 | Teton CME Routing | Disconnected.
2026-10-05 01:43:26.865 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:43:28.874 |
2026-10-05 01:43:28.876 | Teton CME Routing | ....
[2026-10-05 07:36:16]
Sierra_Chart Engineering - Posts: 25458
This log is incomplete. This does not help us at all. When you cut out critical information we cannot have an understanding of what the problem is.
We need to see the entire Message Log or at least, all of the messages, related to one connection attempt. Instructions:
[2026-10-05 08:18:15]
Thank you. I am attaching/pasting the entire Message Log below, including the complete messages related to the connection attempts. Please let me know if you need any additional information.
attachmentmessage log.txt - Attached On 2026-10-05 08:18:04 UTC - Size: 102.01 KB - 70 views
[2026-10-05 08:27:29]
Are you editing this log? This is not the complete content of the log. For example we see:
2026-10-05 02:07:34.245 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:07:36.246 |
2026-10-05 02:07:36.256 | Teton CME Routing | ....( There is no such message like this!)
2026-10-05 02:08:36.259 | Service connection timed out. Will disconnect and retry. *
This is what we should be seeing:
2026-10-05 04:26:38.831 | Teton CME Routing | Firm: Dorman
2026-10-05 04:26:38.831 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091
2026-10-05 04:26:38.832 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2026-10-05 04:26:38.833 | DTC Client socket (1) | New receive buffer size: 0
2026-10-05 04:26:38.833 | DTC Client socket (1) | Connecting to IP: 216.200.108.154 Port: 11091.
2026-10-05 04:26:38.842 | Teton CME Routing | Network connection to server complete.
2026-10-05 04:26:38.842 | Teton CME Routing | Starting socket receive thread.
2026-10-05 04:26:38.843 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none
2026-10-05 04:26:38.873 | Teton CME Routing | Setting DTC encoding to Binary VLS
2026-10-05 04:26:38.873 | Teton CME Routing | Sending logon request message.
2026-10-05 04:26:38.882 | Teton CME Routing | Received logon response.
2026-10-05 04:26:38.882 | Teton CME Routing | Server Name: SC DTC Server. Build=58073.
2026-10-05 04:26:38.882 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8
2026-10-05 04:26:38.882 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2026-10-05 04:26:38.882 | Teton CME Routing | Trading is supported.
2026-10-05 04:26:38.882 | Teton CME Routing | Order cancel and replace is supported.
2026-10-05 04:26:38.882 | Teton CME Routing | OCO Orders supported.
2026-10-05 04:26:38.882 | Teton CME Routing | Bracket Orders supported.
2026-10-05 04:26:38.882 | Teton CME Routing | MarketDepthIsSupported: 1
2026-10-05 04:26:38.882 | Teton CME Routing | Connection to server complete.
2026-10-05 04:26:38.883 | No download requests in the queue to start downloads for. | Number times message added: 4
There is no private information at all. If you are cutting out IP addresses, none of that is private information that belongs to you. That is our information.
Date Time Of Last Edit: 2026-10-05 08:28:57
[2026-10-05 09:38:47]
Thank you. I was not intentionally editing the log. I am now copying the complete Message Log directly from Sierra Chart using “Edit >> Copy Log” and pasting it below without any modifications.
2026-10-05 01:44:28.892 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:44:28.892 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:44:28.892 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:44:28.907 | Teton CME Routing | Failed connections: 104
2026-10-05 01:44:28.907 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:44:28.907 | Teton CME Routing | Disconnected.
2026-10-05 01:44:28.908 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:44:30.908 |
2026-10-05 01:44:30.916 | Teton CME Routing | ....
2026-10-05 01:45:30.921 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:45:30.921 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:45:30.921 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:45:30.937 | Teton CME Routing | Failed connections: 105
2026-10-05 01:45:30.937 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:45:30.937 | Teton CME Routing | Disconnected.
2026-10-05 01:45:30.937 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:45:32.937 |
2026-10-05 01:45:32.940 | Teton CME Routing | ....
2026-10-05 01:46:32.969 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:46:32.969 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:46:32.969 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:46:32.985 | Teton CME Routing | Failed connections: 106
2026-10-05 01:46:32.985 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:46:32.985 | Teton CME Routing | Disconnected.
2026-10-05 01:46:32.985 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:46:35.000 |
2026-10-05 01:46:35.008 | Teton CME Routing | ....
2026-10-05 01:47:35.016 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:47:35.016 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:47:35.016 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:47:35.031 | Teton CME Routing | Failed connections: 107
2026-10-05 01:47:35.031 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:47:35.031 | Teton CME Routing | Disconnected.
2026-10-05 01:47:35.031 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:47:37.046 |
2026-10-05 01:47:37.056 | Teton CME Routing | ....
2026-10-05 01:48:37.062 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:48:37.062 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:48:37.062 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:48:37.077 | Teton CME Routing | Failed connections: 108
2026-10-05 01:48:37.077 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:48:37.077 | Teton CME Routing | Disconnected.
2026-10-05 01:48:37.077 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:48:39.080 |
2026-10-05 01:48:39.088 | Teton CME Routing | ....
2026-10-05 01:49:39.095 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:49:39.095 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:49:39.095 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:49:39.110 | Teton CME Routing | Failed connections: 109
2026-10-05 01:49:39.110 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:49:39.111 | Teton CME Routing | Disconnected.
2026-10-05 01:49:39.111 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:49:41.125 |
2026-10-05 01:49:41.132 | Teton CME Routing | ....
2026-10-05 01:50:41.142 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:50:41.142 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:50:41.142 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:50:41.157 | Teton CME Routing | Failed connections: 110
2026-10-05 01:50:41.157 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:50:41.158 | Teton CME Routing | Disconnected.
2026-10-05 01:50:41.158 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:50:43.172 |
2026-10-05 01:50:43.178 | Teton CME Routing | ....
2026-10-05 01:51:43.188 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:51:43.188 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:51:43.188 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:51:43.219 | Teton CME Routing | Failed connections: 111
2026-10-05 01:51:43.219 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:51:43.219 | Teton CME Routing | Disconnected.
2026-10-05 01:51:43.219 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:51:45.220 |
2026-10-05 01:51:45.229 | Teton CME Routing | ....
2026-10-05 01:52:45.235 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:52:45.235 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:52:45.235 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:52:45.250 | Teton CME Routing | Failed connections: 112
2026-10-05 01:52:45.251 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:52:45.251 | Teton CME Routing | Disconnected.
2026-10-05 01:52:45.251 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:52:47.266 |
2026-10-05 01:52:47.273 | Teton CME Routing | ....
2026-10-05 01:53:47.282 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:53:47.282 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:53:47.282 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:53:47.298 | Teton CME Routing | Failed connections: 113
2026-10-05 01:53:47.298 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:53:47.298 | Teton CME Routing | Disconnected.
2026-10-05 01:53:47.298 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:53:49.313 |
2026-10-05 01:53:49.319 | Teton CME Routing | ....
2026-10-05 01:54:49.328 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:54:49.328 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:54:49.328 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:54:49.343 | Teton CME Routing | Failed connections: 114
2026-10-05 01:54:49.343 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:54:49.343 | Teton CME Routing | Disconnected.
2026-10-05 01:54:49.344 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:54:51.344 |
2026-10-05 01:54:51.352 | Teton CME Routing | ....
2026-10-05 01:55:51.361 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:55:51.361 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:55:51.361 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:55:51.376 | Teton CME Routing | Failed connections: 115
2026-10-05 01:55:51.376 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:55:51.376 | Teton CME Routing | Disconnected.
2026-10-05 01:55:51.377 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:55:53.391 |
2026-10-05 01:55:53.399 | Teton CME Routing | ....
2026-10-05 01:56:53.406 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:56:53.406 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:56:53.406 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:56:53.422 | Teton CME Routing | Failed connections: 116
2026-10-05 01:56:53.422 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:56:53.422 | Teton CME Routing | Disconnected.
2026-10-05 01:56:53.422 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:56:55.423 |
2026-10-05 01:56:55.429 | Teton CME Routing | ....
2026-10-05 01:57:55.437 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:57:55.437 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:57:55.437 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:57:55.453 | Teton CME Routing | Failed connections: 117
2026-10-05 01:57:55.453 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:57:55.453 | Teton CME Routing | Disconnected.
2026-10-05 01:57:55.453 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:57:57.454 |
2026-10-05 01:57:57.464 | Teton CME Routing | ....
2026-10-05 01:58:57.470 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:58:57.470 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:58:57.470 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:58:57.486 | Teton CME Routing | Failed connections: 118
2026-10-05 01:58:57.486 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:58:57.486 | Teton CME Routing | Disconnected.
2026-10-05 01:58:57.486 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:58:59.500 |
2026-10-05 01:58:59.508 | Teton CME Routing | ....
2026-10-05 01:59:59.508 | Service connection timed out. Will disconnect and retry. *
2026-10-05 01:59:59.508 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 01:59:59.508 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 01:59:59.525 | Teton CME Routing | Failed connections: 119
2026-10-05 01:59:59.525 | DTC Client socket (0) | CloseSocket call.
2026-10-05 01:59:59.525 | Teton CME Routing | Disconnected.
2026-10-05 01:59:59.525 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:00:01.532 |
2026-10-05 02:00:01.538 | Teton CME Routing | ....
2026-10-05 02:01:01.541 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:01:01.541 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:01:01.541 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:01:01.557 | Teton CME Routing | Failed connections: 120
2026-10-05 02:01:01.557 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:01:01.557 | Teton CME Routing | Disconnected.
2026-10-05 02:01:01.557 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:01:03.573 |
2026-10-05 02:01:03.581 | Teton CME Routing | ....
2026-10-05 02:02:03.586 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:02:03.586 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:02:03.586 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:02:03.610 | Teton CME Routing | Failed connections: 121
2026-10-05 02:02:03.610 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:02:03.610 | Teton CME Routing | Disconnected.
2026-10-05 02:02:03.610 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:02:05.619 |
2026-10-05 02:02:05.626 | Teton CME Routing | ....
2026-10-05 02:03:05.632 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:03:05.632 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:03:05.632 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:03:05.647 | Teton CME Routing | Failed connections: 122
2026-10-05 02:03:05.648 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:03:05.648 | Teton CME Routing | Disconnected.
2026-10-05 02:03:05.648 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:03:07.649 |
2026-10-05 02:03:07.655 | Teton CME Routing | ....
2026-10-05 02:04:07.679 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:04:07.679 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:04:07.679 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:04:07.695 | Teton CME Routing | Failed connections: 123
2026-10-05 02:04:07.698 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:04:07.700 | Teton CME Routing | Disconnected.
2026-10-05 02:04:07.700 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:04:09.705 |
2026-10-05 02:04:09.716 | Teton CME Routing | ....
2026-10-05 02:05:09.730 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:05:09.730 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:05:09.730 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:05:09.747 | Teton CME Routing | Failed connections: 124
2026-10-05 02:05:09.747 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:05:09.747 | Teton CME Routing | Disconnected.
2026-10-05 02:05:09.747 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:05:11.758 |
2026-10-05 02:05:11.763 | Teton CME Routing | ....
2026-10-05 02:06:09.831 | File >> Disconnect selected.
2026-10-05 02:06:09.831 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:06:09.831 | Teton CME Routing | Disconnected.
2026-10-05 02:06:34.210 |
2026-10-05 02:06:34.216 | Teton CME Routing | ....
2026-10-05 02:07:34.223 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:07:34.223 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:07:34.223 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:07:34.243 | Teton CME Routing | Failed connections: 125
2026-10-05 02:07:34.244 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:07:34.245 | Teton CME Routing | Disconnected.
2026-10-05 02:08:36.259 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:08:36.259 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:08:36.273 | Teton CME Routing | Failed connections: 126
2026-10-05 02:08:36.273 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:08:36.273 | Teton CME Routing | Disconnected.
2026-10-05 02:08:36.274 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:08:38.276 |
2026-10-05 02:08:38.284 | Teton CME Routing | ....
2026-10-05 02:09:38.287 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:09:38.287 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:09:38.287 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:09:38.300 | Teton CME Routing | Failed connections: 127
2026-10-05 02:09:38.300 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:09:38.300 | Teton CME Routing | Disconnected.
2026-10-05 02:09:38.300 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:09:40.308 |
2026-10-05 02:09:40.322 | Teton CME Routing | ....
2026-10-05 02:10:40.330 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:10:40.330 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:10:40.330 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:10:40.347 | Teton CME Routing | Failed connections: 128
2026-10-05 02:10:40.347 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:10:40.347 | Teton CME Routing | Disconnected.
2026-10-05 02:10:40.347 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:10:42.355 |
2026-10-05 02:10:42.363 | Teton CME Routing | ....
2026-10-05 02:11:42.375 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:11:42.375 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:11:42.375 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:11:42.390 | Teton CME Routing | Failed connections: 129
2026-10-05 02:11:42.390 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:11:42.391 | Teton CME Routing | Disconnected.
2026-10-05 02:11:42.391 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:11:44.391 |
2026-10-05 02:11:44.399 | Teton CME Routing | ....
2026-10-05 02:12:44.406 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:12:44.406 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:12:44.406 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:12:44.422 | Teton CME Routing | Failed connections: 130
2026-10-05 02:12:44.422 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:12:44.422 | Teton CME Routing | Disconnected.
2026-10-05 02:12:44.422 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:12:46.427 |
2026-10-05 02:12:46.432 | Teton CME Routing | ....
2026-10-05 02:13:46.454 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:13:46.454 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:13:46.454 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:13:46.470 | Teton CME Routing | Failed connections: 131
2026-10-05 02:13:46.470 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:13:46.470 | Teton CME Routing | Disconnected.
2026-10-05 02:13:46.470 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:13:48.484 |
2026-10-05 02:13:48.490 | Teton CME Routing | ....
2026-10-05 02:14:48.499 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:14:48.499 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:14:48.499 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:14:48.516 | Teton CME Routing | Failed connections: 132
2026-10-05 02:14:48.516 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:14:48.517 | Teton CME Routing | Disconnected.
2026-10-05 02:14:48.517 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:14:50.531 |
2026-10-05 02:14:50.534 | Teton CME Routing | ....
2026-10-05 02:15:50.547 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:15:50.547 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:15:50.547 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:15:50.562 | Teton CME Routing | Failed connections: 133
2026-10-05 02:15:50.562 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:15:50.562 | Teton CME Routing | Disconnected.
2026-10-05 02:15:50.562 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:15:52.563 |
2026-10-05 02:15:52.569 | Teton CME Routing | ....
2026-10-05 02:16:52.578 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:16:52.578 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:16:52.578 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:16:52.594 | Teton CME Routing | Failed connections: 134
2026-10-05 02:16:52.594 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:16:52.594 | Teton CME Routing | Disconnected.
2026-10-05 02:16:52.594 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:16:54.594 |
2026-10-05 02:16:54.603 | Teton CME Routing | ....
2026-10-05 02:17:54.626 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:17:54.626 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:17:54.626 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:17:54.642 | Teton CME Routing | Failed connections: 135
2026-10-05 02:17:54.642 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:17:54.642 | Teton CME Routing | Disconnected.
2026-10-05 02:17:54.642 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:17:56.655 |
2026-10-05 02:17:56.661 | Teton CME Routing | ....
2026-10-05 02:18:56.672 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:18:56.672 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:18:56.672 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:18:56.687 | Teton CME Routing | Failed connections: 136
2026-10-05 02:18:56.687 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:18:56.687 | Teton CME Routing | Disconnected.
2026-10-05 02:18:56.687 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:18:58.688 |
2026-10-05 02:18:58.694 | Teton CME Routing | ....
2026-10-05 02:19:58.704 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:19:58.704 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:19:58.704 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:19:58.719 | Teton CME Routing | Failed connections: 137
2026-10-05 02:19:58.720 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:19:58.720 | Teton CME Routing | Disconnected.
2026-10-05 02:19:58.720 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:20:00.734 |
2026-10-05 02:20:00.742 | Teton CME Routing | ....
2026-10-05 02:21:00.751 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:21:00.751 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:21:00.751 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:21:00.766 | Teton CME Routing | Failed connections: 138
2026-10-05 02:21:00.766 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:21:00.766 | Teton CME Routing | Disconnected.
2026-10-05 02:21:00.766 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:21:02.781 |
2026-10-05 02:21:02.787 | Teton CME Routing | ....
2026-10-05 02:22:02.801 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:22:02.801 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:22:02.801 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:22:02.819 | Teton CME Routing | Failed connections: 139
2026-10-05 02:22:02.819 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:22:02.821 | Teton CME Routing | Disconnected.
2026-10-05 02:22:02.821 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:22:04.830 |
2026-10-05 02:22:04.837 | Teton CME Routing | ....
2026-10-05 02:22:10.676 | File >> Disconnect selected.
2026-10-05 02:22:10.676 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:22:10.676 | Teton CME Routing | Disconnected.
2026-10-05 02:22:17.181 |
2026-10-05 02:22:17.192 | Teton CME Routing | ....
2026-10-05 02:23:17.195 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:23:17.195 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:23:17.195 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:23:17.205 | Teton CME Routing | Failed connections: 140
2026-10-05 02:23:17.205 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:23:17.205 | Teton CME Routing | Disconnected.
2026-10-05 02:23:17.205 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:23:19.221 |
2026-10-05 02:23:19.231 | Teton CME Routing | ....
2026-10-05 02:24:19.241 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:24:19.241 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:24:19.241 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:24:19.259 | Teton CME Routing | Failed connections: 141
2026-10-05 02:24:19.259 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:24:19.261 | Teton CME Routing | Disconnected.
2026-10-05 02:24:19.262 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:24:21.268 |
2026-10-05 02:24:21.274 | Teton CME Routing | ....
2026-10-05 02:25:21.287 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:25:21.287 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:25:21.287 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:25:21.313 | Teton CME Routing | Failed connections: 142
2026-10-05 02:25:21.313 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:25:21.313 | Teton CME Routing | Disconnected.
2026-10-05 02:25:21.313 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:25:23.333 |
2026-10-05 02:25:23.342 | Teton CME Routing | ....
2026-10-05 02:26:23.352 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:26:23.352 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:26:23.352 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:26:23.363 | Teton CME Routing | Failed connections: 143
2026-10-05 02:26:23.363 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:26:23.364 | Teton CME Routing | Disconnected.
2026-10-05 02:26:23.364 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:26:25.380 |
2026-10-05 02:26:25.391 | Teton CME Routing | ....
2026-10-05 02:27:25.406 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:27:25.406 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:27:25.406 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:27:25.444 | Teton CME Routing | Failed connections: 144
2026-10-05 02:27:25.444 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:27:25.444 | Teton CME Routing | Disconnected.
2026-10-05 02:27:25.444 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:27:27.468 |
2026-10-05 02:27:27.474 | Teton CME Routing | ....
2026-10-05 02:28:27.490 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:28:27.490 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:28:27.490 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:28:27.504 | Teton CME Routing | Failed connections: 145
2026-10-05 02:28:27.505 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:28:27.505 | Teton CME Routing | Disconnected.
2026-10-05 02:28:27.505 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:28:29.516 |
2026-10-05 02:28:29.519 | Teton CME Routing | ....
2026-10-05 02:29:29.524 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:29:29.525 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:29:29.525 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:29:29.551 | Teton CME Routing | Failed connections: 146
2026-10-05 02:29:29.551 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:29:29.551 | Teton CME Routing | Disconnected.
2026-10-05 02:29:29.551 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:29:31.551 |
2026-10-05 02:29:31.557 | Teton CME Routing | ....
2026-10-05 02:30:31.558 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:30:31.558 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:30:31.558 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:30:31.570 | Teton CME Routing | Failed connections: 147
2026-10-05 02:30:31.570 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:30:31.570 | Teton CME Routing | Disconnected.
2026-10-05 02:30:31.570 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:30:33.579 |
2026-10-05 02:30:33.585 | Teton CME Routing | ....
2026-10-05 02:31:33.603 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:31:33.603 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:31:33.603 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:31:33.626 | Teton CME Routing | Failed connections: 148
2026-10-05 02:31:33.626 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:31:33.626 | Teton CME Routing | Disconnected.
2026-10-05 02:31:33.626 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:31:35.629 |
2026-10-05 02:31:35.639 | Teton CME Routing | ....
2026-10-05 02:32:35.649 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:32:35.649 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:32:35.649 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:32:35.665 | Teton CME Routing | Failed connections: 149
2026-10-05 02:32:35.666 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:32:35.666 | Teton CME Routing | Disconnected.
2026-10-05 02:32:35.666 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:32:37.679 |
2026-10-05 02:32:37.682 | Teton CME Routing | ....
2026-10-05 02:33:37.684 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:33:37.684 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:33:37.684 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:33:37.700 | Teton CME Routing | Failed connections: 150
2026-10-05 02:33:37.700 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:33:37.702 | Teton CME Routing | Disconnected.
2026-10-05 02:33:37.702 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:33:39.721 |
2026-10-05 02:33:39.726 | Teton CME Routing | ....
2026-10-05 02:33:41.350 | File >> Disconnect selected.
2026-10-05 02:33:41.350 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:33:41.350 | Teton CME Routing | Disconnected.
2026-10-05 02:33:45.266 |
2026-10-05 02:33:45.270 | Teton CME Routing | ....
2026-10-05 02:34:45.278 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:34:45.278 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:34:45.278 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:34:45.294 | Teton CME Routing | Failed connections: 151
2026-10-05 02:34:45.294 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:34:45.295 | Teton CME Routing | Disconnected.
2026-10-05 02:34:45.295 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:34:47.303 |
2026-10-05 02:34:47.306 | Teton CME Routing | ....
2026-10-05 02:35:47.313 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:35:47.313 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:35:47.313 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:35:47.324 | Teton CME Routing | Failed connections: 152
2026-10-05 02:35:47.324 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:35:47.324 | Teton CME Routing | Disconnected.
2026-10-05 02:35:47.324 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:35:49.329 |
2026-10-05 02:35:49.342 | Teton CME Routing | ....
2026-10-05 02:36:49.355 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:36:49.355 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:36:49.355 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:36:49.371 | Teton CME Routing | Failed connections: 153
2026-10-05 02:36:49.372 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:36:49.372 | Teton CME Routing | Disconnected.
2026-10-05 02:36:49.372 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:36:51.381 |
2026-10-05 02:36:51.389 | Teton CME Routing | ....
2026-10-05 02:37:51.401 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:37:51.401 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:37:51.401 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:37:51.420 | Teton CME Routing | Failed connections: 154
2026-10-05 02:37:51.420 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:37:51.420 | Teton CME Routing | Disconnected.
2026-10-05 02:37:51.420 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:37:53.421 |
2026-10-05 02:37:53.423 | Teton CME Routing | ....
2026-10-05 02:38:53.428 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:38:53.428 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:38:53.428 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:38:53.447 | Teton CME Routing | Failed connections: 155
2026-10-05 02:38:53.447 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:38:53.448 | Teton CME Routing | Disconnected.
2026-10-05 02:38:53.448 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:38:55.461 |
2026-10-05 02:38:55.466 | Teton CME Routing | ....
2026-10-05 02:39:55.473 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:39:55.473 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:39:55.473 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:39:55.499 | Teton CME Routing | Failed connections: 156
2026-10-05 02:39:55.500 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:39:55.500 | Teton CME Routing | Disconnected.
2026-10-05 02:39:55.500 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:39:57.513 |
2026-10-05 02:39:57.521 | Teton CME Routing | ....
2026-10-05 02:40:57.529 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:40:57.529 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:40:57.529 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:40:57.559 | Teton CME Routing | Failed connections: 157
2026-10-05 02:40:57.559 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:40:57.559 | Teton CME Routing | Disconnected.
2026-10-05 02:40:57.559 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:40:59.561 |
2026-10-05 02:40:59.571 | Teton CME Routing | ....
2026-10-05 02:41:59.577 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:41:59.577 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:41:59.577 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:41:59.595 | Teton CME Routing | Failed connections: 158
2026-10-05 02:41:59.595 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:41:59.595 | Teton CME Routing | Disconnected.
2026-10-05 02:41:59.595 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:42:01.609 |
2026-10-05 02:42:01.612 | Teton CME Routing | ....
2026-10-05 02:43:04.637 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:43:04.637 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:43:04.637 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:43:04.660 | Teton CME Routing | Failed connections: 159
2026-10-05 02:43:04.660 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:43:04.660 | Teton CME Routing | Disconnected.
2026-10-05 02:43:04.660 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:43:06.665 |
2026-10-05 02:43:06.672 | Teton CME Routing | ....
2026-10-05 02:44:06.681 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:44:06.681 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:44:06.681 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:44:06.692 | Teton CME Routing | Failed connections: 160
2026-10-05 02:44:06.692 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:44:06.692 | Teton CME Routing | Disconnected.
2026-10-05 02:44:06.692 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:44:08.706 |
2026-10-05 02:44:08.709 | Teton CME Routing | ....
2026-10-05 02:45:08.803 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:45:08.803 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:45:08.803 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:45:08.818 | Teton CME Routing | Failed connections: 161
2026-10-05 02:45:08.818 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:45:08.818 | Teton CME Routing | Disconnected.
2026-10-05 02:45:08.818 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:45:10.823 |
2026-10-05 02:45:10.831 | Teton CME Routing | ....
2026-10-05 02:46:10.836 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:46:10.836 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:46:10.836 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:46:10.854 | Teton CME Routing | Failed connections: 162
2026-10-05 02:46:10.854 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:46:10.854 | Teton CME Routing | Disconnected.
2026-10-05 02:46:10.854 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:46:12.869 |
2026-10-05 02:46:12.872 | Teton CME Routing | ....
2026-10-05 02:47:12.875 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:47:12.875 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:47:12.875 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:47:12.890 | Teton CME Routing | Failed connections: 163
2026-10-05 02:47:12.890 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:47:12.890 | Teton CME Routing | Disconnected.
2026-10-05 02:47:12.890 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:47:14.893 |
2026-10-05 02:47:14.895 | Teton CME Routing | ....
2026-10-05 02:48:14.903 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:48:14.903 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:48:14.903 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:48:14.920 | Teton CME Routing | Failed connections: 164
2026-10-05 02:48:14.920 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:48:14.920 | Teton CME Routing | Disconnected.
2026-10-05 02:48:14.920 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:48:16.922 |
2026-10-05 02:48:16.926 | Teton CME Routing | ....
2026-10-05 02:49:16.934 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:49:16.934 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:49:16.934 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:49:16.950 | Teton CME Routing | Failed connections: 165
2026-10-05 02:49:16.950 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:49:16.950 | Teton CME Routing | Disconnected.
2026-10-05 02:49:16.950 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:49:18.976 |
2026-10-05 02:49:18.978 | Teton CME Routing | ....
2026-10-05 02:50:18.985 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:50:18.985 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:50:18.985 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:50:19.020 | Teton CME Routing | Failed connections: 166
2026-10-05 02:50:19.020 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:50:19.020 | Teton CME Routing | Disconnected.
2026-10-05 02:50:19.020 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:50:21.026 |
2026-10-05 02:50:21.033 | Teton CME Routing | ....
2026-10-05 02:51:21.046 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:51:21.046 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:51:21.046 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:51:21.058 | Teton CME Routing | Failed connections: 167
2026-10-05 02:51:21.058 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:51:21.058 | Teton CME Routing | Disconnected.
2026-10-05 02:51:21.058 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:51:23.059 |
2026-10-05 02:51:23.064 | Teton CME Routing | ....
2026-10-05 02:52:23.067 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:52:23.067 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:52:23.067 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:52:23.091 | Teton CME Routing | Failed connections: 168
2026-10-05 02:52:23.091 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:52:23.091 | Teton CME Routing | Disconnected.
2026-10-05 02:52:23.091 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:52:25.098 |
2026-10-05 02:52:25.102 | Teton CME Routing | ....
2026-10-05 02:53:25.109 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:53:25.109 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:53:25.109 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:53:25.120 | Teton CME Routing | Failed connections: 169
2026-10-05 02:53:25.121 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:53:25.122 | Teton CME Routing | Disconnected.
2026-10-05 02:53:25.123 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:53:27.136 |
2026-10-05 02:53:27.148 | Teton CME Routing | ....
2026-10-05 02:54:27.159 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:54:27.159 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:54:27.159 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:54:27.175 | Teton CME Routing | Failed connections: 170
2026-10-05 02:54:27.175 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:54:27.175 | Teton CME Routing | Disconnected.
2026-10-05 02:54:27.175 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:54:29.190 |
2026-10-05 02:54:29.198 | Teton CME Routing | ....
2026-10-05 02:55:29.200 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:55:29.200 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:55:29.200 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:55:29.228 | Teton CME Routing | Failed connections: 171
2026-10-05 02:55:29.228 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:55:29.228 | Teton CME Routing | Disconnected.
2026-10-05 02:55:29.228 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:55:31.228 |
2026-10-05 02:55:31.234 | Teton CME Routing | ....
2026-10-05 02:56:31.236 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:56:31.236 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:56:31.236 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:56:31.252 | Teton CME Routing | Failed connections: 172
2026-10-05 02:56:31.253 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:56:31.253 | Teton CME Routing | Disconnected.
2026-10-05 02:56:31.253 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:56:33.258 |
2026-10-05 02:56:33.261 | Teton CME Routing | ....
2026-10-05 02:57:33.267 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:57:33.267 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:57:33.267 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:57:33.284 | Teton CME Routing | Failed connections: 173
2026-10-05 02:57:33.284 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:57:33.284 | Teton CME Routing | Disconnected.
2026-10-05 02:57:33.284 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:57:35.287 |
2026-10-05 02:57:35.292 | Teton CME Routing | ....
2026-10-05 02:58:35.299 | Service connection timed out. Will disconnect and retry. *
2026-10-05 02:58:35.300 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 02:58:35.300 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:58:35.326 | Teton CME Routing | Failed connections: 174
2026-10-05 02:58:35.327 | DTC Client socket (0) | CloseSocket call.
2026-10-05 02:58:35.327 | Teton CME Routing | Disconnected.
2026-10-05 02:58:35.327 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 02:58:37.330 |
2026-10-05 02:58:37.335 | Teton CME Routing | ....
2026-10-05 02:58:57.656 | Saved Chartbook: ES (SP500) L1 RECOMMENDED Sep 25.Cht. Time: 0.3561 seconds.
2026-10-05 02:58:58.425 | Saved Chartbook: GBPUSD L1 RECOMMENDED Sep 25.Cht. Time: 0.7672 seconds.
2026-10-05 02:58:59.110 | Saved Chartbook: SP500 L1 RECOMMENDED Sep 25.Cht. Time: 0.6790 seconds.
2026-10-05 02:58:59.568 | Saved Chartbook: EURUSD L1 RECOMMENDED Sep 25.Cht. Time: 0.4533 seconds.
2026-10-05 02:58:59.892 | Saved Chartbook: GBPJPY L1 RECOMMENDED Sep 25.Cht. Time: 0.3227 seconds.
2026-10-05 02:59:00.538 | Saved Chartbook: USDJPY L1 RECOMMENDED Sep 25.Cht. Time: 0.6443 seconds.
2026-10-05 02:59:01.100 | Saved Chartbook: GOLD L1 RECOMMENDED Sep 25.Cht. Time: 0.5563 seconds.
2026-10-05 02:59:01.442 | Saved Chartbook: CL CFD (CRUDE OIL) L1 Oct 25.Cht. Time: 0.3401 seconds.
2026-10-05 02:59:01.818 | Saved Chartbook: USDX.Cht. Time: 0.3738 seconds.
2026-10-05 02:59:01.995 | Saved Chartbook: CL (CRUDE OIL) L1 Oct 25.Cht. Time: 0.1732 seconds.
2026-10-05 03:00:16.361 | Service connection timed out. Will disconnect and retry. *
2026-10-05 03:00:16.361 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 03:00:16.361 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:00:16.389 | Teton CME Routing | Failed connections: 175
2026-10-05 03:00:16.390 | DTC Client socket (0) | CloseSocket call.
2026-10-05 03:00:16.390 | Teton CME Routing | Disconnected.
2026-10-05 03:00:16.390 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:00:18.404 |
2026-10-05 03:00:18.405 | Teton CME Routing | ....
2026-10-05 03:00:37.198 | CLX26_FUT_CME [CBV] #2 | Reloading chart.
2026-10-05 03:00:38.948 | Added historical Intraday data request for CLX26_FUT_CME to the queue.
2026-10-05 03:00:38.948 | Intraday data recording state for symbol CLX26_FUT_CME is set to download 'Pending'.
2026-10-05 03:00:38.948 | Triggering next historical data download in queue.
2026-10-05 03:00:39.043 | CLX26_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol CLX26_FUT_CME starting at last date in file.
2026-10-05 03:00:39.144 | Added historical Daily data request for CLX26_FUT_CME to the queue.
2026-10-05 03:00:39.144 | Triggering next historical data download in queue.
2026-10-05 03:00:39.249 | CLX26_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 36, 37,
2026-10-05 03:00:39.565 | CLX26_FUT_CME [CBV] 750 Volume #5 | Reloading chart.
2026-10-05 03:00:39.656 | CLX26_FUT_CME [CBV] 750 Volume #5 | Waiting for historical downloads to complete with the IDs: 36, 37,
2026-10-05 03:00:39.931 | CLX26_FUT_CME [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:00:40.020 | CLX26_FUT_CME [CBV] 10000 Volume #1 | Waiting for historical downloads to complete with the IDs: 36, 37,
2026-10-05 03:00:40.219 | CLX26_FUT_CME [CBV] 40000 Volume #4 | Reloading chart.
2026-10-05 03:00:40.533 | CLX26_FUT_CME [CBV] 40000 Volume #4 | Waiting for historical downloads to complete with the IDs: 36, 37,
2026-10-05 03:00:40.663 | CLX26_FUT_CME [CBV] 5000 Volume #3 | Reloading chart.
2026-10-05 03:00:40.910 | CLX26_FUT_CME [CBV] 5000 Volume #3 | Waiting for historical downloads to complete with the IDs: 36, 37,
2026-10-05 03:00:41.498 | USOil [CBV] #2 | Reloading chart.
2026-10-05 03:00:41.498 | USOil [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:41.498 | USOil [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:41.676 | USOil [CBV] 750 Volume #5 | Reloading chart.
2026-10-05 03:00:41.676 | USOil [CBV] 750 Volume #5 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:41.676 | USOil [CBV] 750 Volume #5 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:42.869 | USOil [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:00:42.870 | USOil [CBV] 10000 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:42.870 | USOil [CBV] 10000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:43.091 | USOil [CBV] 40000 Volume #4 | Reloading chart.
2026-10-05 03:00:43.091 | USOil [CBV] 40000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:43.091 | USOil [CBV] 40000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:43.300 | USOil [CBV] 5000 Volume #3 | Reloading chart.
2026-10-05 03:00:43.300 | USOil [CBV] 5000 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:43.300 | USOil [CBV] 5000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:44.233 | ESZ26_FUT_CME [CBV] #2 | Reloading chart.
2026-10-05 03:00:45.301 | Added historical Intraday data request for ESZ26_FUT_CME to the queue.
2026-10-05 03:00:45.301 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'.
2026-10-05 03:00:45.408 | ESZ26_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol ESZ26_FUT_CME starting at last date in file.
2026-10-05 03:00:45.408 | Added historical Daily data request for ESZ26_FUT_CME to the queue.
2026-10-05 03:00:45.529 | ESZ26_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:45.660 | ESZ26_FUT_CME [CBV] 500 Volume #5 | Reloading chart.
2026-10-05 03:00:45.804 | ESZ26_FUT_CME [CBV] 500 Volume #5 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:45.948 | ESZ26_FUT_CME [CBV] 100000 Volume #1 | Reloading chart.
2026-10-05 03:00:46.005 | ESZ26_FUT_CME [CBV] 100000 Volume #1 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:46.176 | ESZ26_FUT_CME [CBV] 180000 Volume #4 | Reloading chart.
2026-10-05 03:00:46.263 | ESZ26_FUT_CME [CBV] 180000 Volume #4 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:46.477 | ESZ26_FUT_CME [CBV] 5000 Volume #3 | Reloading chart.
2026-10-05 03:00:46.685 | ESZ26_FUT_CME [CBV] 5000 Volume #3 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:46.766 | ESZ26_FUT_CME [CB] 1 Min #7 | Reloading chart.
2026-10-05 03:00:46.861 | ESZ26_FUT_CME [CB] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:48.363 | ESZ26_FUT_CME [CB] 1 Min #6 | Reloading chart.
2026-10-05 03:00:48.426 | ESZ26_FUT_CME [CB] 1 Min #6 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:48.513 | ESZ26_FUT_CME [CB] 1 Min #8 | Reloading chart.
2026-10-05 03:00:48.560 | ESZ26_FUT_CME [CB] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 38, 39,
2026-10-05 03:00:49.263 | EURUSD [CBV] #2 | Reloading chart.
2026-10-05 03:00:49.263 | EURUSD [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:49.263 | EURUSD [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:49.422 | EURUSD [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:00:49.422 | EURUSD [CBV] 10000 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:49.422 | EURUSD [CBV] 10000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:49.604 | EURUSD [CBV] 18000 Volume #4 | Reloading chart.
2026-10-05 03:00:49.604 | EURUSD [CBV] 18000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:49.604 | EURUSD [CBV] 18000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:49.798 | EURUSD [CBV] 500 Volume #6 | Reloading chart.
2026-10-05 03:00:49.798 | EURUSD [CBV] 500 Volume #6 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:49.798 | EURUSD [CBV] 500 Volume #6 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:51.449 | EURUSD [CBV] 5000 Volume #3 | Reloading chart.
2026-10-05 03:00:51.449 | EURUSD [CBV] 5000 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:51.449 | EURUSD [CBV] 5000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:52.104 | GBPJPY [CBV] #2 | Reloading chart.
2026-10-05 03:00:52.104 | GBPJPY [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:52.104 | GBPJPY [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:52.554 | GBPJPY [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:00:52.554 | GBPJPY [CBV] 10000 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:52.554 | GBPJPY [CBV] 10000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:52.811 | GBPJPY [CBV] 18000 Volume #4 | Reloading chart.
2026-10-05 03:00:52.811 | GBPJPY [CBV] 18000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:52.811 | GBPJPY [CBV] 18000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:53.081 | GBPJPY [CBV] 500 Volume #6 | Reloading chart.
2026-10-05 03:00:53.081 | GBPJPY [CBV] 500 Volume #6 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:53.081 | GBPJPY [CBV] 500 Volume #6 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:53.397 | GBPJPY [CBV] 5000 Volume #3 | Reloading chart.
2026-10-05 03:00:53.397 | GBPJPY [CBV] 5000 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:53.397 | GBPJPY [CBV] 5000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:54.688 | GBPUSD [CBV] #2 | Reloading chart.
2026-10-05 03:00:54.688 | GBPUSD [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:54.688 | GBPUSD [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:54.921 | GBPUSD [CBV] 500 Volume #5 | Reloading chart.
2026-10-05 03:00:54.921 | GBPUSD [CBV] 500 Volume #5 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:54.921 | GBPUSD [CBV] 500 Volume #5 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:55.184 | GBPUSD [CBV] 2500 Volume #1 | Reloading chart.
2026-10-05 03:00:55.184 | GBPUSD [CBV] 2500 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:55.184 | GBPUSD [CBV] 2500 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:55.477 | GBPUSD [CBV] 8000 Volume #4 | Reloading chart.
2026-10-05 03:00:55.477 | GBPUSD [CBV] 8000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:55.477 | GBPUSD [CBV] 8000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:55.767 | GBPUSD [CBV] 2500 Volume #3 | Reloading chart.
2026-10-05 03:00:55.767 | GBPUSD [CBV] 2500 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:55.767 | GBPUSD [CBV] 2500 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:56.966 | XAUUSD [CBV] #2 | Reloading chart.
2026-10-05 03:00:56.966 | XAUUSD [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:56.966 | XAUUSD [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:57.270 | XAUUSD [CBV] 5000 Volume #5 | Reloading chart.
2026-10-05 03:00:57.270 | XAUUSD [CBV] 5000 Volume #5 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:57.270 | XAUUSD [CBV] 5000 Volume #5 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:00:59.755 | XAUUSD [CBV] 100000 Volume #1 | Reloading chart.
2026-10-05 03:00:59.755 | XAUUSD [CBV] 100000 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:00:59.755 | XAUUSD [CBV] 100000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:00.029 | XAUUSD [CBV] 180000 Volume #4 | Reloading chart.
2026-10-05 03:01:00.030 | XAUUSD [CBV] 180000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:00.030 | XAUUSD [CBV] 180000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:00.245 | XAUUSD [CBV] 20000 Volume #3 | Reloading chart.
2026-10-05 03:01:00.245 | XAUUSD [CBV] 20000 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:00.245 | XAUUSD [CBV] 20000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:04.415 | M6BZ26_FUT_CME [CBV] #2 | Reloading chart.
2026-10-05 03:01:09.244 | Added historical Intraday data request for M6BZ26_FUT_CME to the queue.
2026-10-05 03:01:09.925 | M6BZ26_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol M6BZ26_FUT_CME starting at last date in file.
2026-10-05 03:01:09.925 | Added historical Daily data request for M6BZ26_FUT_CME to the queue.
2026-10-05 03:01:10.030 | M6BZ26_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 40, 41,
2026-10-05 03:01:10.978 | M6BZ26_FUT_CME [CBV] 25 Volume #5 | Reloading chart.
2026-10-05 03:01:11.160 | M6BZ26_FUT_CME [CBV] 25 Volume #5 | Waiting for historical downloads to complete with the IDs: 40, 41,
2026-10-05 03:01:11.386 | M6BZ26_FUT_CME [CBV] 250 Volume #1 | Reloading chart.
2026-10-05 03:01:11.475 | M6BZ26_FUT_CME [CBV] 250 Volume #1 | Waiting for historical downloads to complete with the IDs: 40, 41,
2026-10-05 03:01:11.792 | M6BZ26_FUT_CME [CBV] 450 Volume #4 | Reloading chart.
2026-10-05 03:01:11.943 | M6BZ26_FUT_CME [CBV] 450 Volume #4 | Waiting for historical downloads to complete with the IDs: 40, 41,
2026-10-05 03:01:12.179 | M6BZ26_FUT_CME [CBV] 100 Volume #6 | Reloading chart.
2026-10-05 03:01:12.481 | M6BZ26_FUT_CME [CBV] 100 Volume #6 | Waiting for historical downloads to complete with the IDs: 40, 41,
2026-10-05 03:01:13.602 | M6EZ26_FUT_CME [CBV] #2 | Reloading chart.
2026-10-05 03:01:14.946 | Added historical Intraday data request for M6EZ26_FUT_CME to the queue.
2026-10-05 03:01:15.095 | M6EZ26_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol M6EZ26_FUT_CME starting at last date in file.
2026-10-05 03:01:15.095 | Added historical Daily data request for M6EZ26_FUT_CME to the queue.
2026-10-05 03:01:15.213 | M6EZ26_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 42, 43,
2026-10-05 03:01:15.420 | M6EZ26_FUT_CME [CBV] 100 Volume #5 | Reloading chart.
2026-10-05 03:01:15.611 | M6EZ26_FUT_CME [CBV] 100 Volume #5 | Waiting for historical downloads to complete with the IDs: 42, 43,
2026-10-05 03:01:15.873 | M6EZ26_FUT_CME [CBV] 1000 Volume #1 | Reloading chart.
2026-10-05 03:01:15.919 | M6EZ26_FUT_CME [CBV] 1000 Volume #1 | Waiting for historical downloads to complete with the IDs: 42, 43,
2026-10-05 03:01:16.116 | M6EZ26_FUT_CME [CBV] 1800 Volume #4 | Reloading chart.
2026-10-05 03:01:16.198 | M6EZ26_FUT_CME [CBV] 1800 Volume #4 | Waiting for historical downloads to complete with the IDs: 42, 43,
2026-10-05 03:01:16.435 | M6EZ26_FUT_CME [CBV] 500 Volume #6 | Reloading chart.
2026-10-05 03:01:16.581 | M6EZ26_FUT_CME [CBV] 500 Volume #6 | Waiting for historical downloads to complete with the IDs: 42, 43,
2026-10-05 03:01:18.103 | NQZ26_FUT_CME [CBV] #2 | Reloading chart.
2026-10-05 03:01:18.789 | Added historical Intraday data request for NQZ26_FUT_CME to the queue.
2026-10-05 03:01:18.833 | NQZ26_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol NQZ26_FUT_CME starting at last date in file.
2026-10-05 03:01:18.833 | Added historical Daily data request for NQZ26_FUT_CME to the queue.
2026-10-05 03:01:18.915 | NQZ26_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:19.104 | NQZ26_FUT_CME [CBV] 500 Volume #5 | Reloading chart.
2026-10-05 03:01:19.980 | NQZ26_FUT_CME [CBV] 500 Volume #5 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:20.176 | NQZ26_FUT_CME [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:01:20.306 | NQZ26_FUT_CME [CBV] 10000 Volume #1 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:20.519 | NQZ26_FUT_CME [CBV] 18000 Volume #4 | Reloading chart.
2026-10-05 03:01:20.631 | NQZ26_FUT_CME [CBV] 18000 Volume #4 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:20.849 | NQZ26_FUT_CME [CBV] 5000 Volume #6 | Reloading chart.
2026-10-05 03:01:20.970 | NQZ26_FUT_CME [CBV] 5000 Volume #6 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:21.443 | NQZ26_FUT_CME [CBV] #2 | Reloading chart.
2026-10-05 03:01:21.651 | NQZ26_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:21.882 | NQZ26_FUT_CME [CBV] 500 Volume #5 | Reloading chart.
2026-10-05 03:01:22.133 | NQZ26_FUT_CME [CBV] 500 Volume #5 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:22.835 | NQZ26_FUT_CME [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:01:22.996 | NQZ26_FUT_CME [CBV] 10000 Volume #1 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:23.623 | NQZ26_FUT_CME [CBV] 18000 Volume #4 | Reloading chart.
2026-10-05 03:01:23.790 | NQZ26_FUT_CME [CBV] 18000 Volume #4 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:24.298 | NQZ26_FUT_CME [CBV] 5000 Volume #6 | Reloading chart.
2026-10-05 03:01:24.461 | NQZ26_FUT_CME [CBV] 5000 Volume #6 | Waiting for historical downloads to complete with the IDs: 44, 45,
2026-10-05 03:01:25.346 | SPX500 [CBV] #2 | Reloading chart.
2026-10-05 03:01:25.346 | SPX500 [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:25.346 | SPX500 [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:25.621 | SPX500 [CBV] 500 Volume #5 | Reloading chart.
2026-10-05 03:01:25.621 | SPX500 [CBV] 500 Volume #5 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:25.621 | SPX500 [CBV] 500 Volume #5 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:27.387 | SPX500 [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:01:27.387 | SPX500 [CBV] 10000 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:27.387 | SPX500 [CBV] 10000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:27.879 | SPX500 [CBV] 18000 Volume #4 | Reloading chart.
2026-10-05 03:01:27.879 | SPX500 [CBV] 18000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:27.879 | SPX500 [CBV] 18000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:28.180 | SPX500 [CBV] 2500 Volume #3 | Reloading chart.
2026-10-05 03:01:28.180 | SPX500 [CBV] 2500 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:28.180 | SPX500 [CBV] 2500 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:29.238 | USDJPY [CBV] #2 | Reloading chart.
2026-10-05 03:01:29.238 | USDJPY [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:29.238 | USDJPY [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:29.459 | USDJPY [CBV] 10000 Volume #1 | Reloading chart.
2026-10-05 03:01:29.459 | USDJPY [CBV] 10000 Volume #1 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:29.459 | USDJPY [CBV] 10000 Volume #1 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:29.683 | USDJPY [CBV] 18000 Volume #4 | Reloading chart.
2026-10-05 03:01:29.683 | USDJPY [CBV] 18000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:29.683 | USDJPY [CBV] 18000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:29.910 | USDJPY [CBV] 500 Volume #6 | Reloading chart.
2026-10-05 03:01:29.910 | USDJPY [CBV] 500 Volume #6 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:29.910 | USDJPY [CBV] 500 Volume #6 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:30.135 | USDJPY [CBV] 5000 Volume #3 | Reloading chart.
2026-10-05 03:01:30.135 | USDJPY [CBV] 5000 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:30.135 | USDJPY [CBV] 5000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:30.921 | USDX [CBV] #2 | Reloading chart.
2026-10-05 03:01:30.921 | USDX [CBV] #2 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:30.921 | USDX [CBV] #2 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:31.403 | USDX [CBV] 1000 Volume #3 | Reloading chart.
2026-10-05 03:01:31.403 | USDX [CBV] 1000 Volume #3 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:31.403 | USDX [CBV] 1000 Volume #3 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:31.698 | USDX [CBV] 10000 Volume #4 | Reloading chart.
2026-10-05 03:01:31.698 | USDX [CBV] 10000 Volume #4 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:31.698 | USDX [CBV] 10000 Volume #4 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:31.969 | USDX [CBV] 18000 Volume #8 | Reloading chart.
2026-10-05 03:01:31.969 | USDX [CBV] 18000 Volume #8 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:31.969 | USDX [CBV] 18000 Volume #8 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:32.263 | USDX [CBV] 5000 Volume #9 | Reloading chart.
2026-10-05 03:01:32.263 | USDX [CBV] 5000 Volume #9 | No contract months found for symbol. Unable to build continuous futures contract chart.
2026-10-05 03:01:32.263 | USDX [CBV] 5000 Volume #9 | There are no continuous futures contract symbols. Loading data normally.
2026-10-05 03:01:33.109 | HD Request # 36 | Downloading Intraday chart data for CLX26_FUT_CME to the file CLX26_FUT_CME.scid. Service: nymex
2026-10-05 03:01:33.110 | HD Request # 36 | Download start date-time: 2026-10-02 16:59:59.000000. File last date-time: 2026-10-02 16:59:59.992000
2026-10-05 03:01:33.113 | HD Request # 37 | Downloading Historical Daily chart data for CLX26_FUT_CME. Starting date: 2026-09-30. Service: sc_futures_direct.dtc.trading
2026-10-05 03:01:33.186 | HD Request # 36 | Using server: ds32.sierracharts.com port 10150
2026-10-05 03:01:33.225 | Service connection timed out. Will disconnect and retry. *
2026-10-05 03:01:33.225 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 03:01:33.225 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:01:33.252 | Teton CME Routing | Failed connections: 176
2026-10-05 03:01:33.253 | DTC Client socket (0) | CloseSocket call.
2026-10-05 03:01:33.253 | Teton CME Routing | Disconnected.
2026-10-05 03:01:33.253 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:01:33.313 | Socket (2) | Creating socket.
2026-10-05 03:01:33.313 | Socket (2) | New receive buffer size: 0
2026-10-05 03:01:33.313 | Socket (2) | Connecting to IP: 69.39.70.248.
2026-10-05 03:01:33.548 | HD Request # 36 | Setting DTC encoding to Binary VLS
2026-10-05 03:01:33.548 | HD Request # 36 | Sending historical data logon request message.
2026-10-05 03:01:33.711 | HD Request # 36 | Requesting Intraday data. Start date-time: 2026-10-02 16:59:59. Record interval: 0. Symbol: CLX26
2026-10-05 03:01:33.738 | HD Request # 37 | Requesting historical Daily data for CLX26 starting at 2026-09-29. SC External HD service.
2026-10-05 03:01:33.826 | HD Request # 36 | Decompressing data.
2026-10-05 03:01:34.178 | HD Request # 37 | Bytes received: 263
2026-10-05 03:01:34.178 | HD Request # 37 | Received 5 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX26_FUT_CME
2026-10-05 03:01:34.178 | HD Request # 37 | Completion time: 1s.
2026-10-05 03:01:34.178 | HD Request # 37 | Daily data download complete for CLX26_FUT_CME. Unique request ID: 37
2026-10-05 03:01:34.178 | Removing historical data download ID 37.
2026-10-05 03:01:34.178 | Triggering next historical data download in queue.
2026-10-05 03:01:34.186 | HD Request # 38 | Downloading Historical Daily chart data for ESZ26_FUT_CME. Starting date: 2026-09-30. Service: sc_futures_direct.dtc.trading
2026-10-05 03:01:34.374 | Socket (2) | CloseSocket call.
2026-10-05 03:01:34.374 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-10-05 03:01:34.375 | Historical data download thread signaled to stop.
2026-10-05 03:01:34.375 | HD Request # 36 | Received 19781 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for CLX26_FUT_CME
2026-10-05 03:01:34.375 | HD Request # 36 | Completion time: 1s.
2026-10-05 03:01:34.375 | HD Request # 36 | Intraday data download complete for CLX26_FUT_CME. Unique request ID: 36
2026-10-05 03:01:34.375 | Removing historical data download ID 36.
2026-10-05 03:01:34.375 | Real-time Intraday chart data file updates started for CLX26_FUT_CME
2026-10-05 03:01:34.375 | Intraday chart data file opened for CLX26_FUT_CME
2026-10-05 03:01:34.375 | HD Request # 36 | Enabling Intraday chart updating for symbol.
2026-10-05 03:01:34.375 | Triggering next historical data download in queue.
2026-10-05 03:01:34.375 | Historical data for CLX26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-10-05 03:01:34.376 | HD Request # 39 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme
2026-10-05 03:01:34.376 | HD Request # 39 | Download start date-time: 2026-10-02 16:59:59.000000. File last date-time: 2026-10-02 16:59:59.993001
2026-10-05 03:01:34.377 | HD Request # 39 | Using server: ds37.sierracharts.com port 10149
2026-10-05 03:01:34.491 | Socket (2) | Socket gracefully closed by remote side.
2026-10-05 03:01:34.491 | Socket (2) | Closed.
2026-10-05 03:01:34.516 | Socket (4) | Creating socket.
2026-10-05 03:01:34.516 | Socket (4) | New receive buffer size: 0
2026-10-05 03:01:34.516 | Socket (4) | Connecting to IP: 4.8.175.92.
2026-10-05 03:01:34.739 | HD Request # 38 | Requesting historical Daily data for ESZ26 starting at 2026-09-29. SC External HD service.
2026-10-05 03:01:34.786 | HD Request # 39 | Setting DTC encoding to Binary VLS
2026-10-05 03:01:34.786 | HD Request # 39 | Sending historical data logon request message.
2026-10-05 03:01:34.974 | HD Request # 39 | Requesting Intraday data. Start date-time: 2026-10-02 16:59:59. Record interval: 0. Symbol: ESZ26
2026-10-05 03:01:34.974 | HD Request # 38 | Bytes received: 294
2026-10-05 03:01:34.974 | HD Request # 38 | Received 5 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ26_FUT_CME
2026-10-05 03:01:34.974 | HD Request # 38 | Completion time: 0s.
2026-10-05 03:01:34.974 | HD Request # 38 | Daily data download complete for ESZ26_FUT_CME. Unique request ID: 39
2026-10-05 03:01:34.974 | Removing historical data download ID 39.
2026-10-05 03:01:34.974 | Triggering next historical data download in queue.
2026-10-05 03:01:34.975 | Mapping M6BZ26_FUT_CME to M6BZ26. Service code: cme
2026-10-05 03:01:35.102 | HD Request # 40 | Downloading Historical Daily chart data for M6BZ26_FUT_CME. Starting date: 2026-09-30. Service: sc_futures_direct.dtc.trading
2026-10-05 03:01:35.104 | HD Request # 39 | Decompressing data.
2026-10-05 03:01:35.269 |
2026-10-05 03:01:35.272 | Teton CME Routing | ....
2026-10-05 03:01:35.671 | HD Request # 40 | Requesting historical Daily data for MBZ26 starting at 2026-09-29. SC External HD service.
2026-10-05 03:01:35.952 | Socket (4) | CloseSocket call.
2026-10-05 03:01:35.952 | Socket (4) | Shutdown started. Waiting for graceful close.
2026-10-05 03:01:35.958 | Historical data download thread signaled to stop.
2026-10-05 03:01:35.958 | HD Request # 39 | Received 71617 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESZ26_FUT_CME
2026-10-05 03:01:35.958 | HD Request # 39 | Completion time: 1s.
2026-10-05 03:01:35.958 | HD Request # 39 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 38
2026-10-05 03:01:35.958 | Removing historical data download ID 38.
2026-10-05 03:01:35.958 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME
2026-10-05 03:01:35.958 | Intraday chart data file opened for ESZ26_FUT_CME
2026-10-05 03:01:35.958 | HD Request # 39 | Enabling Intraday chart updating for symbol.
2026-10-05 03:01:35.959 | Triggering next historical data download in queue.
2026-10-05 03:01:35.959 | Historical data for ESZ26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-10-05 03:01:35.959 | HD Request # 40 | Bytes received: 270
2026-10-05 03:01:35.959 | HD Request # 40 | Received 5 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M6BZ26_FUT_CME
2026-10-05 03:01:35.959 | HD Request # 40 | Completion time: 0s.
2026-10-05 03:01:35.959 | HD Request # 40 | Daily data download complete for M6BZ26_FUT_CME. Unique request ID: 41
2026-10-05 03:01:35.959 | Removing historical data download ID 41.
2026-10-05 03:01:35.959 | HD Request # 41 | Downloading Intraday chart data for M6BZ26_FUT_CME to the file M6BZ26_FUT_CME.scid. Service: cme
2026-10-05 03:01:35.960 | HD Request # 41 | Download start date-time: 2026-10-02 16:59:47.000000. File last date-time: 2026-10-02 16:59:47.893000
2026-10-05 03:01:35.960 | HD Request # 41 | Using server: ds28.sierracharts.com port 10150
2026-10-05 03:01:35.960 | Mapping M6EZ26_FUT_CME to M6EZ26. Service code: cme
2026-10-05 03:01:35.963 | HD Request # 42 | Downloading Historical Daily chart data for M6EZ26_FUT_CME. Starting date: 2026-09-30. Service: sc_futures_direct.dtc.trading
2026-10-05 03:01:36.018 | Socket (2) | Creating socket.
2026-10-05 03:01:36.018 | Socket (2) | New receive buffer size: 0
2026-10-05 03:01:36.018 | Socket (2) | Connecting to IP: 67.214.125.5.
2026-10-05 03:01:36.078 | Socket (4) | Socket gracefully closed by remote side.
2026-10-05 03:01:36.078 | Socket (4) | Closed.
2026-10-05 03:01:36.255 | HD Request # 41 | Setting DTC encoding to Binary VLS
2026-10-05 03:01:36.255 | HD Request # 41 | Sending historical data logon request message.
2026-10-05 03:01:36.405 | HD Request # 41 | Requesting Intraday data. Start date-time: 2026-10-02 16:59:47. Record interval: 0. Symbol: M6BZ26
2026-10-05 03:01:36.521 | HD Request # 41 | Decompressing data.
2026-10-05 03:01:36.564 | HD Request # 42 | Requesting historical Daily data for MFZ26 starting at 2026-09-29. SC External HD service.
2026-10-05 03:01:36.639 | Socket (2) | CloseSocket call.
2026-10-05 03:01:36.639 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-10-05 03:01:36.641 | Historical data download thread signaled to stop.
2026-10-05 03:01:36.641 | HD Request # 41 | Received 324 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for M6BZ26_FUT_CME
2026-10-05 03:01:36.641 | HD Request # 41 | Completion time: 1s.
2026-10-05 03:01:36.641 | HD Request # 41 | Intraday data download complete for M6BZ26_FUT_CME. Unique request ID: 40
2026-10-05 03:01:36.641 | Removing historical data download ID 40.
2026-10-05 03:01:36.641 | Real-time Intraday chart data file updates started for M6BZ26_FUT_CME
2026-10-05 03:01:36.641 | Intraday chart data file opened for M6BZ26_FUT_CME
2026-10-05 03:01:36.641 | HD Request # 41 | Enabling Intraday chart updating for symbol.
2026-10-05 03:01:36.641 | Triggering next historical data download in queue.
2026-10-05 03:01:36.641 | Historical data for M6BZ26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-10-05 03:01:36.642 | HD Request # 43 | Downloading Intraday chart data for M6EZ26_FUT_CME to the file M6EZ26_FUT_CME.scid. Service: cme
2026-10-05 03:01:36.642 | HD Request # 43 | Download start date-time: 2026-10-02 16:59:57.000000. File last date-time: 2026-10-02 16:59:57.769001
2026-10-05 03:01:36.643 | HD Request # 43 | Using server: ds32.sierracharts.com port 10149
2026-10-05 03:01:36.643 | Socket (3) | Creating socket.
2026-10-05 03:01:36.643 | Socket (3) | New receive buffer size: 0
2026-10-05 03:01:36.643 | Socket (3) | Connecting to IP: 69.39.70.248.
2026-10-05 03:01:36.711 | HD Request # 42 | Bytes received: 281
2026-10-05 03:01:36.711 | HD Request # 42 | Received 5 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M6EZ26_FUT_CME
2026-10-05 03:01:36.711 | HD Request # 42 | Completion time: 1s.
2026-10-05 03:01:36.711 | HD Request # 42 | Daily data download complete for M6EZ26_FUT_CME. Unique request ID: 43
2026-10-05 03:01:36.711 | Removing historical data download ID 43.
2026-10-05 03:01:36.711 | Triggering next historical data download in queue.
2026-10-05 03:01:36.711 | Mapping NQZ26_FUT_CME to NQZ26. Service code: cme
2026-10-05 03:01:36.714 | HD Request # 44 | Downloading Historical Daily chart data for NQZ26_FUT_CME. Starting date: 2026-09-30. Service: sc_futures_direct.dtc.trading
2026-10-05 03:01:36.755 | Socket (2) | Socket gracefully closed by remote side.
2026-10-05 03:01:36.755 | Socket (2) | Closed.
2026-10-05 03:01:36.878 | HD Request # 43 | Setting DTC encoding to Binary VLS
2026-10-05 03:01:36.878 | HD Request # 43 | Sending historical data logon request message.
2026-10-05 03:01:37.022 | HD Request # 43 | Requesting Intraday data. Start date-time: 2026-10-02 16:59:57. Record interval: 0. Symbol: M6EZ26
2026-10-05 03:01:37.138 | HD Request # 43 | Decompressing data.
2026-10-05 03:01:37.259 | HD Request # 44 | Requesting historical Daily data for NQZ26 starting at 2026-09-29. SC External HD service.
2026-10-05 03:01:37.392 | Socket (3) | CloseSocket call.
2026-10-05 03:01:37.392 | Socket (3) | Shutdown started. Waiting for graceful close.
2026-10-05 03:01:37.393 | Historical data download thread signaled to stop.
2026-10-05 03:01:37.393 | HD Request # 43 | Received 4411 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for M6EZ26_FUT_CME
2026-10-05 03:01:37.393 | HD Request # 43 | Completion time: 1s.
2026-10-05 03:01:37.393 | HD Request # 43 | Intraday data download complete for M6EZ26_FUT_CME. Unique request ID: 42
2026-10-05 03:01:37.393 | Removing historical data download ID 42.
2026-10-05 03:01:37.393 | Real-time Intraday chart data file updates started for M6EZ26_FUT_CME
2026-10-05 03:01:37.393 | Intraday chart data file opened for M6EZ26_FUT_CME
2026-10-05 03:01:37.393 | HD Request # 43 | Enabling Intraday chart updating for symbol.
2026-10-05 03:01:37.393 | Triggering next historical data download in queue.
2026-10-05 03:01:37.393 | Historical data for M6EZ26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-10-05 03:01:37.394 | HD Request # 45 | Downloading Intraday chart data for NQZ26_FUT_CME to the file NQZ26_FUT_CME.scid. Service: cme
2026-10-05 03:01:37.395 | HD Request # 45 | Download start date-time: 2026-10-02 16:59:58.000000. File last date-time: 2026-10-02 16:59:58.696001
2026-10-05 03:01:37.395 | HD Request # 45 | Using server: ds37.sierracharts.com port 10150
2026-10-05 03:01:37.395 | Socket (2) | Creating socket.
2026-10-05 03:01:37.395 | Socket (2) | New receive buffer size: 0
2026-10-05 03:01:37.395 | Socket (2) | Connecting to IP: 4.8.175.92.
2026-10-05 03:01:37.403 | HD Request # 44 | Bytes received: 311
2026-10-05 03:01:37.403 | HD Request # 44 | Received 5 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ26_FUT_CME
2026-10-05 03:01:37.403 | HD Request # 44 | Completion time: 1s.
2026-10-05 03:01:37.403 | HD Request # 44 | Daily data download complete for NQZ26_FUT_CME. Unique request ID: 45
2026-10-05 03:01:37.403 | Removing historical data download ID 45.
2026-10-05 03:01:37.403 | No download requests in the queue to start downloads for.
2026-10-05 03:01:37.507 | Socket (3) | Socket gracefully closed by remote side.
2026-10-05 03:01:37.508 | Socket (3) | Closed.
2026-10-05 03:01:37.643 | HD Request # 45 | Setting DTC encoding to Binary VLS
2026-10-05 03:01:37.643 | HD Request # 45 | Sending historical data logon request message.
2026-10-05 03:01:37.823 | HD Request # 45 | Requesting Intraday data. Start date-time: 2026-10-02 16:59:58. Record interval: 0. Symbol: NQZ26
2026-10-05 03:01:37.944 | HD Request # 45 | Decompressing data.
2026-10-05 03:01:38.779 | Socket (2) | CloseSocket call.
2026-10-05 03:01:38.780 | Socket (2) | Shutdown started. Waiting for graceful close.
2026-10-05 03:01:38.781 | Historical data download thread signaled to stop.
2026-10-05 03:01:38.781 | HD Request # 45 | Received 58799 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQZ26_FUT_CME
2026-10-05 03:01:38.781 | HD Request # 45 | Completion time: 1s.
2026-10-05 03:01:38.781 | HD Request # 45 | Intraday data download complete for NQZ26_FUT_CME. Unique request ID: 44
2026-10-05 03:01:38.781 | Removing historical data download ID 44.
2026-10-05 03:01:38.781 | Real-time Intraday chart data file updates started for NQZ26_FUT_CME
2026-10-05 03:01:38.781 | Intraday chart data file opened for NQZ26_FUT_CME
2026-10-05 03:01:38.781 | HD Request # 45 | Enabling Intraday chart updating for symbol.
2026-10-05 03:01:38.781 | No download requests in the queue to start downloads for.
2026-10-05 03:01:38.781 | Historical data for NQZ26_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2026-10-05 03:01:38.901 | Socket (2) | Socket gracefully closed by remote side.
2026-10-05 03:01:38.901 | Socket (2) | Closed.
2026-10-05 03:02:35.295 | Service connection timed out. Will disconnect and retry. *
2026-10-05 03:02:35.295 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 03:02:35.295 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:02:35.309 | Teton CME Routing | Failed connections: 177
2026-10-05 03:02:35.310 | DTC Client socket (0) | CloseSocket call.
2026-10-05 03:02:35.310 | Teton CME Routing | Disconnected.
2026-10-05 03:02:35.310 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:02:37.317 |
2026-10-05 03:02:37.322 | Teton CME Routing | ....
2026-10-05 03:03:37.338 | Service connection timed out. Will disconnect and retry. *
2026-10-05 03:03:37.338 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 03:03:37.338 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:03:37.356 | Teton CME Routing | Failed connections: 178
2026-10-05 03:03:37.356 | DTC Client socket (0) | CloseSocket call.
2026-10-05 03:03:37.356 | Teton CME Routing | Disconnected.
2026-10-05 03:03:37.356 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:03:39.381 |
2026-10-05 03:03:39.388 | Teton CME Routing | ....
2026-10-05 03:04:39.390 | Service connection timed out. Will disconnect and retry. *
2026-10-05 03:04:39.390 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 03:04:39.390 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:04:39.408 | Teton CME Routing | Failed connections: 179
2026-10-05 03:04:39.408 | DTC Client socket (0) | CloseSocket call.
2026-10-05 03:04:39.408 | Teton CME Routing | Disconnected.
2026-10-05 03:04:39.408 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:04:41.415 |
2026-10-05 03:04:41.420 | Teton CME Routing | ....
2026-10-05 03:05:25.331 | DTC Client socket (0) | CloseSocket call.
2026-10-05 03:05:25.331 | Teton CME Routing | Disconnected.
2026-10-05 03:05:26.165 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 2.
2026-10-05 03:05:26.165 | Current selected Data/Trading service: SC Data
2026-10-05 03:05:27.658 | Symbol settings MD5 received. Request ID: 2.
2026-10-05 03:05:27.658 | Requested symbol settings for service code scdataallservices. Request ID: 3.
2026-10-05 03:05:28.703 | Symbol settings received. Request ID: 3.
2026-10-05 03:05:32.175 | SC Data | Disconnected. | Number times message added: 1
2026-10-05 03:05:32.414 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 03:05:32.550 | Mapping ESZ26-CME to ESZ26. Service code: cme
2026-10-05 03:05:34.435 |
2026-10-05 03:05:34.438 | SC Data | Connection to server complete.
2026-10-05 03:05:34.457 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-10-05 03:05:34.688 | Mapping ESZ26-CME to ESZ26. Service code: cme
2026-10-05 03:05:34.688 | Using symbol data fast lookup vector
2026-10-05 03:05:34.689 | Delayed Data Feed | Starting real-time market data updates for: ESZ26-CME (ESZ26). ID: 1 Service code: cme
2026-10-05 03:05:34.689 | Delayed Data Feed | ....
2026-10-05 03:05:34.689 | Delayed Data Feed | Requesting security definition data for: ESZ26-CME (ESZ26). ID: 1
2026-10-05 03:17:14.095 | Reloading all Intraday charts in active chartbook.
2026-10-05 03:17:22.672 | Reloading all Historical Daily charts in active chartbook.
2026-10-05 04:12:10.081 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:12:10.150 | Delayed Data Feed | Disconnected from the server.
2026-10-05 04:12:10.367 | SC Data | Disconnected. | Number times message added: 1
2026-10-05 04:12:15.477 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 4.
2026-10-05 04:12:15.519 | Current selected Data/Trading service: Teton CME Routing
2026-10-05 04:12:19.831 | Symbol settings MD5 received. Request ID: 4.
2026-10-05 04:12:19.831 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 5.
2026-10-05 04:12:20.847 | Symbol settings received. Request ID: 5.
2026-10-05 04:12:23.374 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:12:23.905 | Mapping ESZ26_FUT_CME to ESZ26. Service code: cme
2026-10-05 04:12:25.404 |
2026-10-05 04:12:25.412 | Teton CME Routing | ....
2026-10-05 04:13:25.422 | Service connection timed out. Will disconnect and retry. *
2026-10-05 04:13:25.422 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 04:13:25.422 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:13:25.464 | Teton CME Routing | Failed connections: 1
2026-10-05 04:13:25.464 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:13:25.464 | Teton CME Routing | Disconnected.
2026-10-05 04:13:25.464 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:13:27.468 |
2026-10-05 04:13:27.471 | Teton CME Routing | ....
2026-10-05 04:14:27.484 | Service connection timed out. Will disconnect and retry. *
2026-10-05 04:14:27.484 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 04:14:27.484 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:14:27.500 | Teton CME Routing | Failed connections: 2
2026-10-05 04:14:27.500 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:14:27.500 | Teton CME Routing | Disconnected.
2026-10-05 04:14:27.500 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:14:29.516 |
2026-10-05 04:14:29.525 | Teton CME Routing | ....
2026-10-05 04:15:29.531 | Service connection timed out. Will disconnect and retry. *
2026-10-05 04:15:29.531 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 04:15:29.531 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:15:29.547 | Teton CME Routing | Failed connections: 3
2026-10-05 04:15:29.547 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:15:29.547 | Teton CME Routing | Disconnected.
2026-10-05 04:15:29.547 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:15:31.547 |
2026-10-05 04:15:31.549 | Teton CME Routing | ....
2026-10-05 04:16:31.566 | Service connection timed out. Will disconnect and retry. *
2026-10-05 04:16:31.566 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 04:16:31.566 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:16:31.581 | Teton CME Routing | Failed connections: 4
2026-10-05 04:16:31.581 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:16:31.581 | Teton CME Routing | Disconnected.
2026-10-05 04:16:31.582 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:16:33.594 |
2026-10-05 04:16:33.602 | Teton CME Routing | ....
2026-10-05 04:17:33.614 | Service connection timed out. Will disconnect and retry. *
2026-10-05 04:17:33.614 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 04:17:33.614 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:17:33.630 | Teton CME Routing | Failed connections: 5
2026-10-05 04:17:33.630 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:17:33.630 | Teton CME Routing | Disconnected.
2026-10-05 04:17:33.630 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:17:35.644 |
2026-10-05 04:17:35.647 | Teton CME Routing | ....
2026-10-05 04:18:35.649 | Service connection timed out. Will disconnect and retry. *
2026-10-05 04:18:35.649 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-10-05 04:18:35.649 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:18:35.664 | Teton CME Routing | Failed connections: 6
2026-10-05 04:18:35.664 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:18:35.664 | Teton CME Routing | Disconnected.
2026-10-05 04:18:35.664 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:18:37.688 |
2026-10-05 04:18:37.693 | Teton CME Routing | ....
2026-10-05 04:18:54.988 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:18:54.988 | Teton CME Routing | Disconnected.
2026-10-05 04:18:55.599 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 6.
2026-10-05 04:18:55.599 | Current selected Data/Trading service: SC Data
2026-10-05 04:18:57.564 | Symbol settings MD5 received. Request ID: 6.
2026-10-05 04:18:57.564 | Requested symbol settings for service code scdataallservices. Request ID: 7.
2026-10-05 04:18:58.073 | SC Data | Disconnected. | Number times message added: 1
2026-10-05 04:18:58.194 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-10-05 04:18:58.701 | Symbol settings received. Request ID: 7.
2026-10-05 04:19:00.204 |
2026-10-05 04:19:00.211 | SC Data | Connection to server complete.
2026-10-05 04:19:00.648 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-10-05 04:19:00.688 | Mapping ESZ26-CME to ESZ26. Service code: cme
2026-10-05 04:19:00.688 | Using symbol data fast lookup vector
2026-10-05 04:19:00.698 | Delayed Data Feed | Starting real-time market data updates for: ESZ26-CME (ESZ26). ID: 1 Service code: cme
2026-10-05 04:19:00.698 | Delayed Data Feed | ....
2026-10-05 04:19:00.724 | Delayed Data Feed | Requesting security definition data for: ESZ26-CME (ESZ26). ID: 1
2026-10-05 04:36:12.122 | File >> Disconnect selected.
2026-10-05 04:36:12.123 | DTC Client socket (0) | CloseSocket call.
2026-10-05 04:36:12.123 | Delayed Data Feed | Disconnected from the server.
2026-10-05 04:36:12.123 | SC Data | Disconnected.
2026-10-05 04:36:15.299 |
2026-10-05 04:36:15.301 | SC Data | Connection to server complete.
2026-10-05 04:36:15.302 | No download requests in the queue to start downloads for. | Number times message added: 3
2026-10-05 04:36:15.486 | Mapping ESZ26-CME to ESZ26. Service code: cme
2026-10-05 04:36:15.487 | Using symbol data fast lookup vector
2026-10-05 04:36:15.487 | Delayed Data Feed | Starting real-time market data updates for: ESZ26-CME (ESZ26). ID: 1 Service code: cme
2026-10-05 04:36:15.487 | Delayed Data Feed | ....
2026-10-05 04:36:15.487 | Delayed Data Feed | Requesting security definition data for: ESZ26-CME (ESZ26). ID: 1
[2026-10-05 12:22:13]
User340373 - Posts: 12
Its working now thank you!
[2026-10-05 21:51:53]
Sierra_Chart Engineering - Posts: 25458
We actually now realize what the problem is. This is something we have not seen before. This is why we had the impression the log was getting edited. The first thing to do is if you ever encounter this condition, is to restart Sierra Chart.
We also want you to update Sierra Chart to the current version. Instructions:
