Date/Time: Mon, 20 May 2024 03:33:19 +0000
Volume Profile Sizing
View Count: 852
[2014-11-07 04:51:29] |
User78442 - Posts: 260 |
Hi, is there a quick way to resize the horizontal width of a MP display (? I've looked at scaling but its not obvious. Many thanks
[2014-11-08 08:41:15] |
Just sorted it!
[2014-11-12 03:21:44] |
It can be quickly resized only if it was drawn by using the Draw Volume Profile tool.
