Date/Time: Sat, 18 May 2024 21:05:32 +0000
hello support...
View Count: 786
[2014-11-07 00:49:32] |
User53765 - Posts: 66 |
Sorry different topic question. For the SC Historical data that is available can you please tell me where that feed is coming from and is it tick data like the Sierra Realtime feed or is it another type of feed all together that should or should not be relied upon for most accurate cumulative delta values? |
[2014-11-07 02:47:40] |
We are not willing to answer the question as presented because it is not going to give you the information that you need. The tick by tick data with bid volume and ask volume that it provides is accurate. Tick by tick data is only provided for the major futures contracts with the Sierra Chart Historical Data Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
