Date/Time: Mon, 09 Nov 2026 15:14:20 +0000
Running 2 SierraChart's on different computers
View Count: 202
| [2026-09-29 12:35:17] |
| User453636 - Posts: 28 |
Dear Support Team! I'm wishing to run 2 sierrachart-s on 2 different computers. One computer will only have one chartbook open with COMEX GC denali data. The other one will have open 2 chartbooks with only CME NQ denali data. Do I need to purchase any adicional data / service to be able to do this? Thank's in advance! |
| [2026-09-29 14:17:23] |
| John - SC Support - Posts: 48464 |
Yes, you do need to pay a second set of exchange fees in order to allow the data to be accessed from both systems. It does not matter that you are only using certain data/exchanges with each system. Refer to the following for information/instructions: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
