Date/Time: Mon, 09 Nov 2026 15:12:18 +0000
Service Package Does Not Support Data Feed
View Count: 394
[2026-09-29 04:41:34]
User775729 - Posts: 1
My Sierra Chart free trial is active until 2026-10-13. I am using XAUUSD from _Free_Trial_Symbols. Login is successful and the Message Log shows 'Received 5 login tokens'. However, File → Connect to Data Feed gives: 'Service Package does not support this function or account is expired.' The log also says historical data downloads are not enabled. Please check and enable my trial data entitlement.
[2026-09-29 09:32:49]
User135243 - Posts: 331
try to verfiy your email and it should work, they have changed something:
https://www.sierrachart.com/UserControlPanel.php?page=EmailVerification
[2026-09-29 14:01:33]
John - SC Support - Posts: 48464
You do need to verify your email to use the trial.
