Date/Time: Sat, 14 Nov 2026 09:58:09 +0000
data doesnt load when i log in
View Count: 227
| [2026-09-28 04:54:39] |
| User870729 - Posts: 1 |
hi, i dont know why but after i log in the datafeed doesnt connect. i tried re updating the software again but it doesnt work. i tried hitting "connect to data" in the file section. Please help. i understand this thread may have already been created. but i also come to realize i cannot get around this without a team member. thank you so much.
| [2026-09-28 15:55:30] |
| John - SC Support - Posts: 48527 |
The first thing is that you need to verify your email address in order to use the trial. You can do this at the following link: https://www.sierrachart.com/UserControlPanel.php?page=EmailVerification Second, be aware that there is a limited list of symbols available during a trial, and the amount of data is limited. Refer to the following: Sierra Chart Trial Account For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
