Date/Time: Sat, 07 Nov 2026 15:17:25 +0000
Example links fail to load.
View Count: 243
[2026-09-22 20:58:38]
LittleBB - Posts: 19
Example links on this page do not load:
Sierra Chart Image Upload Service
A direct link to an image. https://www.sierrachart.com/image.php?Image=1193343421_6_UploadImage.png (error)
A link to an image with the note. https://www.sierrachart.com/image.php?folder=upload_2&Image=1193343421_6_UploadImage.png (error)
https://www.sierrachart.com/image.php?Image=135898499218.png (endless loading box pops up)
https://www.sierrachart.com/image.php?Image=1358985044722.png (endless loading box pops up)
[2026-09-22 21:12:48]
John - SC Support - Posts: 48459
We will look into the links on the page that are not working.
But where did you get the other two links from? We are referring to these two:
These two files do not exist in the Image Gallery, which is why you are having a problem with them. Did you upload them at one time and then delete them since then?
There are no images in the Image Gallery associated with your account. Do you believe there should be? Did you delete them all at some point?
[2026-09-22 21:30:35]
No they are referenced on that same page towards the top
[2026-09-22 21:31:18]
Upload Chart
This command will upload an image of the chart currently in view. This will not include any windows which are overlaid on top of the chart. Example
Upload Chart with Overlays
This command will upload an image of the chart currently in view with all windows above it. Example
[2026-09-23 14:15:52]
Thank you for the information.
We have updated the page and removed the examples.
