Date/Time: Fri, 06 Nov 2026 01:37:05 +0000
Package 12 - VIX Volatility Index
View Count: 251
| [2026-09-21 21:42:29] |
| lieatishfan - Posts: 6 |
Hi, I've subscribed to Service package 12 and had difficulty opening the VIX Volatility Index chart - I've just submitted the "Uniform Subscriber Agreement CGIF (CBOE Global Index Feed)", wondering if there are any other agreements/fees I should be aware of to gain access?
| [2026-09-22 14:23:46] |
| John - SC Support - Posts: 48449 |
We see that you have the "CBOE Global Indices - Main" exchange active, so you should be fine. If you are still having a problem, then are you entering the symbol for the chart as "VIX_CGI"? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
