Date/Time: Fri, 06 Nov 2026 01:37:01 +0000
Question NES
View Count: 213
[2026-09-21 16:29:08]
User709400 - Posts: 3
Hello i load the NES Chart,
booked rithmyc data feed with amp future
but it actually not work.
What is to do.
Thanky you for your good service.
Best Jens
[2026-09-21 17:04:28]
You are setup to get your data from Rithmic. Therefore, you need to ask Rithmic about whether they are supplying the data for that symbol or not. Or, why you may be having an issue getting that data from Rithmic.
[2026-09-21 17:11:04]
I ask already AMP
and the answer is i need to use Denali with sierra chart,
but i dont know how to do this??
Thank you for help
conversation with amp
ony Pickett (AMP Futures (USA))
21. Sept. 2026, 11:29 AM GMT-5
In order for you to get any data for Sierra Charts you must use Denali.
Jens Busse
21. Sept. 2026, 11:20 AM GMT-5
I booked actually booked data feed with rithmic from amp
What is to do?
Gesendet mit der WEB.DE Mail App
Am 21.09.26, 18:13 schrieb AMP <support@ampfutures.com>:
Tony Pickett (AMP Futures (USA))
21. Sept. 2026, 11:13 AM GMT-5
Are you subscribing to Denala?
Jens Busse
21. Sept. 2026, 10:59 AM GMT-5
Sierra
[2026-09-21 18:28:34]
We are sorry that AMP was not able to answer this properly.
You can get your data either from Rithmic or from our Denali Exchange Data Feed. The choice is yours.
Right now, and for however long you have been using Sierra Chart connected to Rithmic, you have been getting your data from Rithmic, as you have never setup an exchange with our Denali Exchange Data Feed to get any data from us.
We do not know the status of the data for the new Micro products from Rithmic. This is why you would need to talk to AMP/Rithmic about this. But apparently AMP is not able to give a proper answer, so maybe you need to talk to Rithmic directly.
With regards to our Denali Exchange Data Feed, you had filled out the exchange agreements for this back in 2024, so the only thing you would need to do is to activate the exchanges for which you want the real-time data. You can do this for the CME Group at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
Keep in mind that in order to get the real-time data for the CME Group at the non-professional rates, you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Your AMP account with Rithmic supports this, so if you continue to use that account and if you are connecting nearly every day to trade that account, then there is nothing special you need to do.
