Date/Time: Fri, 06 Nov 2026 01:38:02 +0000
Prop account with Data feed Denali
View Count: 222
| [2026-09-21 11:00:15] |
| aftmassi - Posts: 1 |
It is possible to open new positions with a prop firm account while using Denali as the data feed instead of Rithmic.
| [2026-09-21 12:17:02] |
| User135243 - Posts: 330 |
yes of course, but you've to connect a real live account that you can subscribe to Denali realtime-data and use Rithmic-connection just for order-routing.
| [2026-09-21 16:41:09] |
| John - SC Support - Posts: 48449 |
Refer to the following: Denali Exchange Data Feed: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
