Date/Time: Fri, 06 Nov 2026 01:37:15 +0000
Data gap
View Count: 246
[2026-09-21 06:51:57]
diecal67 - Posts: 7
I downloaded 11 years of Denali intraday historical data with 1-tick resolution, but for every single day, the CVD (Cumulative Volume Delta) data is missing for the first 60 minutes of the session! Why is this happening? How can I fix this issue and ensure that all data is loaded correctly from the start of the session through to the end?
https://i.postimg.cc/rsmrHF0B/buco-nei-dati.jpg
[2026-09-21 16:03:18]
We do not understand why you are saying that the Cumulative Delta - Volume data is missing for the first 60 minutes. We do not see any missing data in the image you provided.
The only thing we wonder, given the image, is if you are completely missing an hour's data from the chart. This would be due to your Session Times. Refer to the following:
Chart Session Times
Date Time Of Last Edit: 2026-09-21 18:34:26
[2026-09-21 18:31:19]
diecal67 - Posts: 7
OK, that was the problem... thanks to you, John, it's now resolved. Thanks for your patience.
