Date/Time: Mon, 09 Nov 2026 04:48:56 +0000
Intraday data
View Count: 435
| [2026-09-18 18:07:51] |
| User411320 - Posts: 379 |
Hello, I'm using time charts 10 min , 15 min, and 60 min. Also , renko charts. all with the current contract intraday data. My question is how can i still use these charts but pull/use data from over a year ago? |
| [2026-09-18 18:33:56] |
| John - SC Support - Posts: 48459 |
First of all, we want to point out that the exchange that you had active in July with our Denali Exchange Data Feed did not automatically renew on September 1, 2026, due to insufficient funds in your account at that time. You can activate the exchange(s) for which you want real-time data for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges -- As to the issue of historical data, you have access to all the historical data we have available. For the CME Group, this can go as far back as 2008, so there is no issue with getting data for 1 year prior. If you are wanting to open a chart for a specific contract, then you type in the specific contract you want in the "Selected Symbol" field on the Find Symbol window. For instance, to view the September 2025 contract for ES, you would enter ESU25_FUT_CME. Only 1 year of contracts is listed in the listings at the top of the Find Symbol window. If you are wanting to get data within a chart using the current front contract, then you need to use the "Continuous Futures Contract" option. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-30 14:28:49] |
Hello John, Yes I'm fine with delayed data at the moment as I'm not trading just trying to build a system. In regards to the historical data, how can I have access to all data from , for example (9/30/2025-9/30/2026) for an intraday chart (15 mins)? |
| [2026-09-30 14:54:15] |
| [2026-10-02 13:35:36] |
Thank you, I was able to figure it out with your help
