Date/Time: Sun, 01 Nov 2026 12:12:18 +0000
ROLLOVER ESZ26
View Count: 216
| [2026-09-16 18:19:41] |
| User431406 - Posts: 6 |
hi support team, what is the right command for rollover using the back adjusted the candles are printed on different levels than using based rollover https://www.sierrachart.com/image.php?Image=1789582596795.png |
| [2026-09-16 18:22:17] |
| John - SC Support - Posts: 48377 |
The method you choose to use for rollover is up to you. Refer to the following for an understanding of what back-adjustment does: Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
