Date/Time: Fri, 30 Oct 2026 17:42:03 +0000
No rollover notification? NQ, ES, YM, RTY
View Count: 237
| [2026-09-15 13:41:23] |
| n8trading - Posts: 87 |
Didn't get a rollover notification in SC v2936 for NQ, ES, YM, or RTY. This issue has happened in the past and was resolved, but appears to have returned. Thank you, |
| [2026-09-15 14:23:35] |
| Sierra_Chart Engineering - Posts: 25326 |
Make sure this option is enabled: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) One thing to be aware of is the message that gets displayed with this function, does not display on the chart continuously. Eventually it will clear. And make sure you are running an up-to-date version of Sierra Chart (Important): Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-15 14:35:53
