Date/Time: Sun, 01 Nov 2026 12:12:19 +0000
Volume Per Second as a Candlestick
View Count: 366
[2026-09-15 11:54:33]
User272030 - Posts: 11
I am looking to reference the volume / sec subgraph in the number bars calculated values study to plot a candlestick of volume / second in a chart region below the main price graph. I don't see candlestick as a draw style though... bar draw style ends up showing a bar up to the current or closing value of volume / sec, but looking for a candlestick draw style that would show a wick and thus a visual of the max volume / sec reached as well as the close value of volume / sec. Is this possible in some other way?
Thanks.
[2026-09-15 15:23:21]
There is no direct way to do this in Sierra Chart. The "Volume per Second" that is displayed in the Numbers Bars Calculated Values is the total volume of the bar divided by the number of seconds that make up the bar. So essentially an average volume per second.
To get the Maximum value along with the closing value, you would need to analyze the underlying data for whatever period you are wanting. To do this, you would have to create a custom study. Refer to the following:
Advanced Custom Study Interface and Language (ACSIL): Introduction
[2026-09-17 10:56:33]
Thanks & understood.... a more direct way of candlestick draw style would be a nice new feature though.
[2026-09-17 14:40:57]
cmet - Posts: 743
You might find this study useful.
Put in ACS_Source
Analysis > Build Custom Studies dll > Build With Visual C++ Release
Add Custom Study > Volume Rate
Date Time Of Last Edit: 2026-09-17 14:44:48
attachmentVolumeRate.cpp - Attached On 2026-09-17 14:39:41 UTC - Size: 20.66 KB - 57 views
imagevolrate.jpg / V - Attached On 2026-09-17 14:44:45 UTC - Size: 167.03 KB - 57 views
[2026-09-17 15:24:23]
You can create a candlestick based study by using the "Spreadsheet Formula - Bar" study. This allows you to define the Open/High/Low/Close of a bar using the Alert syntax. So you can reference other studies that are producing the information you are wanting.
