Date/Time: Thu, 29 Oct 2026 17:00:39 +0000
Connection is not made
View Count: 149
[2026-09-14 13:07:03]
User582666 - Posts: 13
My Sierra chart tries to reconnect but fails. I have everything paid, as far as I know. Both the 11 package and the Denali service is active.
Why can't I connect?
[2026-09-14 15:42:54]
John - SC Support - Posts: 48366
What trading/data service are you trying to connect to?
If you are having a problem connecting, you should be getting an error message. Typically, it would be a popup on the screen, but there should be something in your Message Log if you are not getting something explicit. Please tell us exactly what the message states if you are getting one.
[2026-09-14 15:45:58]
Sierra_Chart Engineering - Posts: 25307
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
