Date/Time: Thu, 29 Oct 2026 16:59:06 +0000
BOJUR ...METTRE UNE ALERTE
View Count: 260
[2026-09-14 12:02:37]
User539608 - Posts: 11
JE VOUDRAIS METTRE UNE ALERTE SUR MA CHART 30 MN ....... ALERT CONDITION CLOSE ABOVE SD1 BELOW SD2 OR CLOSE BELOW SD -1 ABOVE SD -2...JE VOUDRAIS QUE L ALERTE SONNE FORT JUSQU A QUE JE L ETEIGNE ..CHAQUE JOUR ENTRE GLOBEX OPEN 18H JUSQU 06H HEURE DE NEW YORK
MERCI POUR VOTRE AIDE
imageSALAH ALERT.png / V - Attached On 2026-09-14 12:01:15 UTC - Size: 45.04 KB - 37 views
[2026-09-14 15:41:28]
John - SC Support - Posts: 48366
From Google Translate:
I would like to set an alert on my 30-minute chart... Alert condition: close above SD1 and below SD2, or close below SD-1 and above SD-2... I would like the alert to sound loudly until I turn it off... every day between the Globex open (6:00 PM) and 6:00 AM New York time.
Thanks for your help.
The general information for setting up alerts is at the following link:
Study/Chart Alerts And Scanning
The general instructions for setting up an Alert Sound is at the following link:
General Settings Window: Configuring Alert Number Instructions
In particular, note the following option for having an alert sound multiple times. You can set this to a very large number:
General Settings Window: Number of Times to Play This Alert (Global Settings >> General Settings >> Alerts >> Alert Settings)
And then refer to the following for how to clear the alert sound queue:
Global Settings Menu: Clear Alert Sound Queue (Global Settings menu)
