Date/Time: Tue, 03 Nov 2026 17:35:28 +0000
v2949 - Quoteboards are gone
View Count: 635
[2026-09-12 07:02:25]
User135243 - Posts: 330
After updating to version 2949 all my Quoteboards on each Chartbook are gone.
(and no, under Quote and Settings is nothing to attach/detach window, everything is greyed out)
[2026-09-12 12:07:18]
Sierra_Chart Engineering - Posts: 25362
Locate the Quote Boards through the CW menu. They will be listed there.
[2026-09-12 12:14:09]
The Quote Boards might be listed with the same name on the CW menu but that will be resolved in the next release where they will have the actual internal number shown on the CW menu after "Quote Board".
Date Time Of Last Edit: 2026-09-12 12:14:40
[2026-09-12 12:59:31]
cmet - Posts: 743
Mine was tabbed into the interface with the rest of my charts at the bottom. Ctrl > Alt > D to restore.
[2026-09-12 14:33:42]
Ok thanks, yes the Quoteboards are under CW listed as "Hidden Quoteboard". I've to click this that I can see it again and attach it (using the new Quote tab) and drag and replace and resize it to the "old" place where it was before.
Not really a smart solution, I've to do it for each Quoteboard and for each Chartbook.
Date Time Of Last Edit: 2026-09-12 14:36:21
[2026-09-14 07:48:08]
Problem solved with v2950, thank you very much!
[2026-09-14 07:58:54]
Regarding post #5 we just had not yet worked on the upgrade functionality for Quote Boards in 2949, but this is now done in version 2950.
[2026-09-19 17:44:07]
ameetmedi - Posts: 52
I've noticed functionality of Quote boards change. Where as before they would float on top of the charts in a size I preferred and kept that sizing while I moved from CB to CB. However now if the chart in my CB Is maximized, the QB now opens also full maximized so you have to switch to that window to see the quotes and then back to your Desktop that has the main SC application. Now I'm on a Mac using this through Crossover but everything worked till a recent update where no matter if I detach the Quote window and move it on chart window and enable Always on Top, if I switch to another CB and then back to the one that has the QB it will now not be floating on my chart but in a full maximized window. It would be nice to have a QB function as an Associated Watchlist to have it float on the charts
[2026-09-19 19:41:20]
We are checking on this. The Quote Board is now based on our detachable window class, and we will add support to that class to have it be an owned window like the Time and Sales window was before.
Date Time Of Last Edit: 2026-09-19 19:42:11
[2026-09-20 13:39:53]
user_xyz - Posts: 529
Quoteboard v2953
Right Click Menu has bugs.
- Right click Roll Forward/Backward futures symbol. Menu reappears after selecting one of those options and the symbol doesn't roll until you click away
- Right click Insert/Delete row menu re-appears.
Now that Quoteboard class has been upgraded are there controls for ACSIL? Having empty/zero values across all quotes over the weekend not ideal.
[2026-09-20 16:25:48]
We will look into this issue.
No, this is completely unrelated.
We cannot help further with this this. This is just how it is. Use charts instead. Charts provide historical data.
[2026-09-20 16:43:42]
Please do not ask about this again:
This is simply never going to come because exchanges do not provide this information over the weekend and the Quote Board shows current values, from the exchange.
It does not matter what we previously said regarding an effort to support this. It is not going to come at this time! Never if the exchanges do not provide this information over the weekend! They simply do not.
[2026-09-20 17:22:38]
We found the problem with the context menu occurring twice. This will be resolved in a new release coming out in about 20 minutes.
Another thing we realize though is that the insertion row when inserting rows occurs at the current selection row but you could end up right clicking somewhere else. So we have to resolve that but that's more involved.
[2026-09-21 06:21:01]
User197029 - Posts: 77
I am on SC2953, using separate Quote Boards in different Chartbooks, and the problems are still happening:
-Quote Boards disappear. I can bring them back by selecting them through the CWmenu, but they disappear again later.
-Enabling Always on Top makes them appear across all Chartbooks, rather than only their own.
-Attaching/detaching helps temporarily. When I return to a Chartbook, the Quote Board’s header sometimes disappears and parts of the charts underneath show through. On another switch back, the Quote Board disappears entirely again.
Before these changes, my Quote Boards stayed where I put them and displayed correctly within their respective Chartbooks. Now I am repeatedly trying to restore them while working.
Can you please restore the previous Quote Board behaviour, or provide an option to use it? The current behaviour in 2953 is not reliable.
[2026-09-21 06:47:01]
Calculus - Posts: 153
On 2954 and it's still messed up.
Quote boards that should always be visible on different tabs are still only sometimes visible on certain tabs, not on others.
[2026-09-21 06:53:19]
The most likely reason you notice this is based on a misunderstanding of how the new Quote Board's work:
The Quote Board is still visible. It has to be. You just need to access it through the System taskbar.
When you notice this go to the Window menu and select Maximize. Should not be anything wrong other than needing to maximize.
There will be a new option in an upcoming release for the old window functionality:
[2026-09-21 07:31:41]
So you have more than one Quote Board attached? How many Quote Boards are attached to the main window?
We will test and see what we can determine.
[2026-09-21 08:24:14]
John
I have some Quote Boards within the main program window, and some that are unattached so outside the main program window.
The unattached one's are set to be visible with all chart books but they're not, only on some chartbooks. For example, I have once chartbook looking at Gold and another for ES. The Quoteboards are set to appear on all chartbooks but only appear on one of the tabs.
There are also other problems such as (attached) Quoteboards disappearing BEHIND the main program window if say the Status bar is highlighted (such as clicking Global Settings). To get them back you have to keep clicking on the Windows taskbar to push them in front of the main program window. It's very annoying as you can imagine.
[2026-09-22 14:10:34]
We understand the issues with the Quote Board. There is a definitely improper behavior with them when changing between Chartbooks, when they are attached. We understand the issue when they are detached. We are working on all of this today.
Date Time Of Last Edit: 2026-09-22 14:10:44
[2026-09-23 04:14:36]
Version 2956 has been released and resolves all outstanding Quote Board issues.
We will start a thread describing the different window states now supported with Quote Boards and we will extend this functionality to Charts and Spreadsheets as well.
[2026-09-23 06:25:35]
Refer to this thread:
New Quote Board Features and Recent Resolved issues with Quote Board
