Date/Time: Sun, 25 Oct 2026 22:23:30 +0000
Linking multiple accounts on sierra charts
View Count: 174
| [2026-09-10 17:42:22] |
| User338995 - Posts: 16 |
I currently use Ironbeam with Sierra Chart and Teton Order Routing. I now have five separate Ironbeam trading accounts and would like to set them up correctly in my existing Sierra Chart installation. Please provide the exact Sierra Chart documentation and step-by-step procedure for: 1. Making all five trading accounts available in Sierra Chart. 2. Verifying that Sierra Chart recognizes all five accounts. 3. Selecting and trading the individual accounts. 4. Configuring Order Allocation to Trade Accounts so that one order can be allocated across all five accounts, if supported. 5. Any Sierra Chart settings required for this configuration. 6. The recommended procedure for safely testing the setup before placing live trades. Please include links to the applicable Sierra Chart documentation. Thank you. Ricardo |
| [2026-09-10 17:52:42] |
| John - SC Support - Posts: 48317 |
If all of these accounts are part of the same account with your broker, then there is nothing special you need to do. When you set your Sierra Chart for live trading, all five of those accounts will show in the "Account Selection" menu on the "Trade Window". Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) You select which account is used for each chart through that Trade Window for each chart. To configure the Order Allocation to Trade Accounts, refer to the following: Order Allocation to Trade Accounts: Setup Instructions It is up to you to test the configuration as you see fit. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
