Date/Time: Sun, 25 Oct 2026 08:29:05 +0000
(Remove weekend data) Not working?
View Count: 218
[2026-09-09 20:16:07]
Elvis.S - Posts: 15
Hei, im using version 2948. Noticed 2 issues, am I doing something wrong or is it bug?
1) Chart settings - Session times - Weekend data - Do not load weekend data
Sunday data still visible
2) General settings - use monday as start of week instead of sunday - YES
Study Period OHLC variable period
Time period type - weeks
OHLC lines still start from sunday open
[2026-09-09 20:27:58]
John - SC Support - Posts: 48317
For Futures, the Sunday evening data is part of the Monday trading day. So when you say to exclude the weekend data, that particular item is ignored. Generally, there should not be any data over the weekend, although there are a few products that do trade over the weekend, and it is growing.
The same is true for what you are seeing with the OHLC Variable Period. Sunday evening data is considered part of Monday, so the week is always going to start at 17:00 on Sunday in Central US Time.
If you are wanting to remove just the Sunday evening data, and have the other evening data for the rest of the week show, then there is not a good way to do this in Sierra Chart.
If you do not want any evening data, then set your Session Times to not use the Evening Session. Refer to the following:
Chart Session Times: Use Evening Session (optional) (Chart >> Chart Settings >> Session Times)
