Date/Time: Fri, 23 Oct 2026 18:37:33 +0000
chart not updating
View Count: 209
[2026-09-08 15:01:58]
User538826 - Posts: 11
Hi i am having problems with my charts updating. it seems to be frozen. i have restarted sierra chart, candles start printing for a few minutes but then freeze. i have also tried disconnecting and reconnecting but the same problem occurs. i have tried it on another symbol and that works fine however in my current GC charts candles seem to be stuck.
[2026-09-08 16:10:18]
John - SC Support - Posts: 48315
What is the symbol of that chart as it is set in "Chart >> Chart Settings >> Symbol >> Symbol"?
And please get us your Message Log by following these instructions for that symbol:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2026-09-08 16:49:44]
Hi i ended up sorting the issue. It was set on a contract that had very thin volume.
