Date/Time: Fri, 23 Oct 2026 18:37:58 +0000
Delayed Trading Evaluator: inconsistent TradingIsDisabled values
View Count: 255
[2026-09-08 11:26:40]
User600279 - Posts: 1
Hello Sierra Chart Support,
We are testing a read-only DTC client on the Delayed Trading Evaluator WebSocket endpoint wss://tradesimulation1.sierracharts.com:11095. On 8 September 2026 the server identifies as SC DTC Server, Build 58044, protocol version 8.
For a newly created simulated USD account with TradingIsDisabled explicitly set to 1, we receive these values for the same account:
- ACCOUNT_SETTINGS_RESPONSE (10116): TradingIsDisabled = 1.
- TRADE_ACCOUNT_RESPONSE (401): TradingIsDisabled = 0.
- ACCOUNT_BALANCE_UPDATE (600): TradingIsDisabled = 1.
The cash balance is 0, IsUnderRequiredAccountValue is 1, and we have not submitted orders or balance adjustments. Our client currently refuses to declare a consistent inventory because the flags disagree.
Do these three fields have different documented meanings on this service? Which fields should a client use to determine whether new orders are blocked, while retaining the configured account-level trading lock?
Please clarify the protocol semantics only. Please do not enable trading, alter account settings or balances, or place any orders.
Thank you.
[2026-09-08 22:06:48]
Sierra_Chart Engineering - Posts: 25250
What we need to know is trading actually disabled on the account?
[2026-09-09 00:41:33]
We did look into this some more and if trading is disabled on the account, this message will not indicate that:
Although the field is there it is not used within this specific context for which you are getting it.
Date Time Of Last Edit: 2026-09-09 00:42:10
