Date/Time: Fri, 23 Oct 2026 04:05:49 +0000
Quote Board Window Displays Only the Header After Using the Move Feature
View Count: 265
| [2026-09-07 08:21:50] |
| Deenius - Posts: 162 |
Hello, On Friday, I reported two bugs in the Quote Board window. Quote Board Bugs Unfortunately, I've discovered one more. If I use the Move feature when the window is minimized, then after clicking the Restore icon, my window remains minimized to just the header and does not return to its previous state. I have to resize it back to the desired dimensions myself. Take a look at the video. https://youtu.be/cKjXcIdolZ8 Could you please take a look at this? Thank you. |
| [2026-09-07 09:35:00] |
| Sierra_Chart Engineering - Posts: 25248 |
We will check on this.
| [2026-09-08 04:28:21] |
We looked at this more closely and this is 100% an operating system level issue. Sierra Chart does not implement the Window Move functionality. Also in the next release the Quote Board will be like a chart and can be attached into the main window of Sierra Chart or detached. And when it is detached we do not see a command to Move it when it is minimized to the taskbar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-09 08:51:48] |
I just downloaded the SC pre-release version (2948). I absolutely love that I can now arrange the quote board window within the chartbook! It would be great if this were possible for the Time and Sales and Market Depth windows as well. Unfortunately, when a chart is attached, the menu doesn’t appear, and you can’t hide the title bar or the scroll bar, as you can with regular chart windows. I just wanted to let you know, in case you weren’t aware of this. Date Time Of Last Edit: 2026-09-09 08:53:07
| [2026-09-09 14:30:55] |
| John - SC Support - Posts: 48303 |
When the Quote Board is attached, the menu for it is located with the other menu items for the main window. You will see a "Quote" menu item between "Spreadsheet" and "Trade" to control the Quote Board. As to the scrollbar, if you do not have fields that go beyond the edge of the visible area, then the scrollbar will not show. But the opposite is true, as there is no other way to move the quote board so that you can view the fields that are off the edge of the visible area. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
