Date/Time: Thu, 22 Oct 2026 03:13:44 +0000
Quote Board Bugs
View Count: 430
[2026-09-04 18:22:34]
Deenius - Posts: 162
I encountered two bugs while configuring the Quote Board.
1. When I enable the “Use Large Number Suffix” feature, it doesn’t adjust the values in the Open Interest column (see screenshot).
2. When I select a cell and then click inside it, other rows start getting selected as if I were holding down the Shift key (which I’m not). Here’s a video:
https://youtu.be/_1_Uolug-p8
Could you please take a look at this? Thank you.
imageOpen Interest.jpg / V - Attached On 2026-09-04 18:22:01 UTC - Size: 1.25 MB - 76 views
[2026-09-04 18:28:38]
user_xyz - Posts: 526
SC - FWIW This has been an issue for a very long time, year+ just never said anything.
[/quote] 2. When I select a cell and then click inside it, other rows start getting selected as if I were holding down the Shift key (which I’m not). Here’s a video:
[2026-09-07 22:43:12]
Sierra_Chart Engineering - Posts: 25234
We are going over this. 1 is easy to resolve.
As we look at number 2, it is not totally clear, what you are describing in comparison to the video but we do see a lot of area of improvement with selection functionality and some inconsistent behavior, and we are going to be working on this.
[2026-09-08 07:17:24]
I'm pointing out that clicking in a cell triggers the multi-line selection feature (see my screenshot).
imageQuote board.jpg / V - Attached On 2026-09-08 07:16:49 UTC - Size: 237.5 KB - 59 views
[2026-09-08 07:32:39]
This should be resolved in the next release. We cannot reproduce it at the moment but we have already done some work to resolve what would seem like a related issue.
Date Time Of Last Edit: 2026-09-08 07:33:19
