Date/Time: Thu, 22 Oct 2026 15:42:58 +0000
Trade Symbol w/CQG Amp & Denali
View Count: 210
| [2026-09-06 22:31:09] |
| user_xyz - Posts: 526 |
Maybe I have this backwards but can't get this separate instance of SC running with Denali, CQG AMP (order routing only). Current Setup. Selected Service > CQG Webapi w/ Common Settings > Allow Support for Sierra Data Feeds: Yes. Symbol CQG for Chart is F.US.ENQu26 (CQG symbol) and since not paying for AMP/CQG data, I'm using Denali (across all other instances) chart is delayed. Trading works fine since I'm sending my trades from a separate dedicated instance running Denali, I copy the trade to this Instance and it executes. Setup I want. NQU26-CME data on chart using Denali data with order routed to CQG F.US.ENQU26. I tried adding NQU26-CME as Trade and Current Quote Symbol and Use As Trade Symbol Only: No would get me Denali data and orders routed to CQG F.US.ENQU26 but this doesn't work. If I reverse and put NQU26-CME as Symbol and F.US.ENQU26 as Trade and Quote Symbol the Denali NQU26-CME symbol isn't recognized. I can't change the Data/Trade Service to SC Data because then I'm not logged into CQG account for routing orders. Date Time Of Last Edit: 2026-09-06 22:33:49
| [2026-09-07 00:29:12] |
| Sierra_Chart Engineering - Posts: 25243 |
You just simply use the symbol F.US.ENQU26, as the one and only symbol in the chart and the market data will come from the Denali Exchange Data Feed. Refer to: Denali Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
