Date/Time: Wed, 21 Oct 2026 15:50:46 +0000
Adding new Symbol
View Count: 230
| [2026-09-06 08:09:31] |
| Kalyani Wevita - Posts: 5 |
I would like to demo trade Nikkei 225 Mini — Osaka Exchange. Is this possible with my current account set up?
| [2026-09-06 15:51:48] |
| Sierra_Chart Engineering - Posts: 25229 |
Yes you can do this with Trade Simulation Mode: Trade Simulation And we recommend using the CME Nikkei 225 futures: NIYU26-CME This is the current contract. You can find them in File >> Find Symbol >> Futures-CME. You can also create a Continuous Futures Contract Chart: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-06 15:52:51
| [2026-09-06 21:29:31] |
| VaiMyFractalRange - Posts: 10 |
The question was not related to CME. I trade Osaka. You need to connect to Interactive brokers. Once yo do, enable sim mode (or connect to IBKR demo account). Make sure you have Osaka data subscription through IBKR and you are ready to go Another option is AMP with CQG. CQG has Osaka. Hope this helps |
| [2026-09-06 22:17:50] |
For Interactive Brokers we see this symbol in File >> Find Symbol >> Futures: N225-######-OSE.JPN-JPY-1000 Is this not the correct symbol? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
