Date/Time: Sun, 29 Nov 2026 22:43:05 +0000
CME Data Not Loading in Real-Time
View Count: 452
| [2026-08-30 22:13:27] |
| HARK - Posts: 10 |
CME data is not loading in real-time. Only on data reload. Please check the server issues. Thank you. |
| [2026-08-30 22:21:00] |
| User303857 - Posts: 201 |
seems something is off ?
| [2026-08-30 22:35:06] |
| Sierra_Chart Engineering - Posts: 25523 |
We do not see any problems with CME data this evening. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-08-30 22:46:22] |
Sent the log file to you.
| [2026-08-30 22:47:37] |
| HARK - Posts: 10 |
I was able to resolve the error. I had a second copy of Sierra loaded. I apologize for the inconvenience
| [2026-08-30 22:48:04] |
looks like it is working now!
| [2026-08-30 22:52:28] |
Regarding post #5, yes that would be the explanation. Regarding post #4 we did not look at the Message Log because you say it is working now. Nothing was changed at our side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
