Date/Time: Sat, 18 May 2024 21:54:52 +0000
Current Price line covering the entire chart
View Count: 959
[2014-11-05 05:22:03] |
User91026 - Posts: 16 |
This is a pretty simply question most likely and i have searched on the support board/google etc to no avail. so asking for help here. Is there a way to display a horizontal line for the current price that covers either the whole chart window, half the chart window or a line that extends per user configuration? there is probably something out there but i am just blind and i can't see it. Thanks for any response and your time in advance. |
[2014-11-06 04:41:14] |
There is a study called Current Price Line which is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s123 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
