Date/Time: Mon, 23 Nov 2026 23:10:36 +0000
Region Scrolling
View Count: 262
| [2026-08-24 17:27:42] |
| Jaydtrade - Posts: 125 |
Is it possible to seperate scrolling horizontally from Region 1 to Region 2? I want to see more on region 2 and leave region 1 as is. I dont think this is possible but wanted to ask just in case I missed it somewhere. Thank you!
| [2026-08-24 19:22:51] |
| John - SC Support - Posts: 48633 |
There is not a way to do this within a single chart. All regions share the same horizontal scaling. The only way to do this would be with two different charts. You can set whatever study you are wanting to view as the "Main Price Graph" so it is the only thing in that other chart. Refer to the following: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
