Date/Time: Mon, 23 Nov 2026 23:10:37 +0000
Help with chart
View Count: 233
[2026-08-23 19:12:35]
User921512 - Posts: 10
While using the hand tool, I am not able to move the chart up and down only side to side. How do I fix this? I'm sure it is a simple fix, I just can't find it. Version 2942
Thank you.
[2026-08-24 15:01:58]
John - SC Support - Posts: 48633
Refer to the following:
Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options)
