Date/Time: Wed, 25 Nov 2026 09:28:01 +0000
RBOB
View Count: 265
[2026-08-20 00:07:46]
User142031 - Posts: 5
Hello Sierra Chart Support,
I’m having an issue locating and loading the RBV26 RBOB Gasoline futures contract. I’ve searched through the Find Symbol → Futures → CME/NYMEX tree, but the standard RB contract months do not appear. Only RBT (TAS) and RBF (Financial) versions are listed.
Here are the specifics:
I am trying to load the physical RBOB contract: RBV26
Typing RBV26 into the chart symbol box does not resolve to a valid symbol
The CME/NYMEX → RB folder does not show any RB contract months
Other NYMEX instruments load normally, so the Denali feed appears active
I want to confirm whether RB outright contracts require a separate NYMEX Energy authorization or if there is a symbol‑mapping issue
Could you please advise on:
Whether RB outright contracts require a specific NYMEX Energy exchange activation
Whether there is a known issue with RB symbol visibility or mapping
Any steps I should take to restore RB contract access
Thank you,
Michael
[2026-08-20 14:02:41]
Our servers show that you are connected to the "Teton CME Routing". If this is correct, then the RB symbol is listed in the "File >> Find Symbol" window under the "Futures - NYMEX" section. It should be between "QM?##_FUT_CME" and "RBT?##_FUT_CME".
If it is not there, then please tell us what "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" is set to for your system.
