Date/Time: Tue, 17 Nov 2026 19:06:57 +0000
Do you have this tool? if not, could it be developed?
View Count: 323
[2026-08-18 16:05:15]
User121101 - Posts: 18
Hi, I was curious if there would be a way to create a Standard Deviation Tracker or Tracer. I was wondering if one could click on a high or low point where an exact entry could be taken to match the R of a previous move. See my attached pic for an idea. I hope that makes sense. Thanks in advance.
imageScreenshot (47)-sd Tracers.png / V - Attached On 2026-08-18 16:05:11 UTC - Size: 212.58 KB - 121 views
[2026-08-18 16:07:11]
John - SC Support - Posts: 48562
We do not understand what exactly you are looking for.
Refer to the following for a drawing tool that does a regression:
Chart Drawing Tools: Raff Regression Channel
