Date/Time: Tue, 17 Nov 2026 20:11:05 +0000
loading time while changing symbols
View Count: 278
[2026-08-18 12:34:22]
davidprudhvihamza - Posts: 1
so , i check multiple symbols and want accurate charts , i use 5 , 15 , 30 , 1hr and 4h charts the most and use number bars , various profiles , and continous charts with volume bases rollover , back adjusted and use about 186 days of tick data , bcz i need to check the charts on higher timeframes , so the problem is the data is downloaded but while chainging timeframes and loading charts , its taking a lot of time to load and its frustuating , i thought seirra would be fast , earlier i used to use a cloud based software " go charting " where it used to be super speed and instant while changing symbols , but here when i try to change symbols or change timesframes its taking tonne of time , so what should i do here to get accurate data and fast loading speed or elese should i open every chartbook and keep it running but im afraid it takes a lot of ram and data , help me here of what should i do to keep the charts speed and accurate data , i use higher timeframes for profiles and cvd , and lower timeframes for number charts atm
[2026-08-18 14:25:33]
John - SC Support - Posts: 48563
The only thing we can really say is to go through the items at the following link regarding improving performance (including loading times):
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
